Intro (re-introduction?)
0 Members and 1 Guest are viewing this topic. Read 2773 times.
katterwaul
    • http://cognitivevent.com/
« on: 20 Jul 2025, 02:27 pm »
Looks like the last time I posted here was 2007 as 'pRC' - yoiks
Happy long-time DIY tube guy here in North Carolina. I've been a tube junkie since I first built a bottlehead kit in 1999.
Current projects: Tuning crossovers for active 4-way speakers built around Azurahorns with field-coil Lowthers running full range. Also several passed modding a Schiit Freya+
Out-of-date log of projects here:
https://www.cognitivevent.com/in_av/av_updates.html
Yeah, it's a bit... scattered at times.
Let's throw in an image - first pass at a block diagram for the Schiit Freya+ (any feedback welcome)
katterwaul
Re: Intro (re-introduction?)
« Reply #1 on: 21 Jul 2025, 05:27 pm »
OK, cool, it looks like the forum engine resized my schematic to 1024 pixels wide - here's a better version at that rez
katterwaul
« Reply #2 on: 21 Jul 2025, 05:59 pm »
Current system... Analog in:
Lenco TT with reworked bearing, laminated cherry base
  • Schick 12-inch tonearm with ebony 'donut' over brass counterweight
  • Denon 103R cartridge transplanted into an alloy case
or Empire 298 TT with stacked plywood base
  • Moth/Rega tonearm with Pete Riggle's VTAF (VTA adjuster)
  • Ebony head shell spacer and Dynavector DV 20x (low) cartridge
> Bottlehead 'Eros' kit phono stage with internal RCA mic transformers, Dueland signal caps, custom Faraday cage case
(and MM inputs with other step-up XFMRs)
> Schiit Freya+ F preamp
  • Tung-Sol mouse ear 6SN7 gain tubes
  • CBS 6SN7 buffer tubes
  • Replaced tube plate and cathode load resistors
  • Replaced all four output caps with Dueland CAST PP/Silver 2.2uF 250V
> Bottlehead 'Stereomour' 12AT7:2A3 amplifier
  • NOS 6201 driver tube and JJ 2A3 40 output tubes
  • Split final B+ filter section into separate LC for each channel
  • Lots of nice Mundorf parts in PS and signal chain
  • 12 gauge copper top plate
> Field-coil magnet Lowthers in 160Hz Azurahorns (fiberglass front horn about a meter in diameter) running full range
Supporting the Azurahorns:
> Douk Audio T8 pro equalizer (NOS 6922 tubes) > 130W digital amp > Dual 15-inch Silver Iris OB woofers with second order low pass crossovers
> Schitt Vali3 (NOS 5670 tube) > Schitt REKKR 2W amp > Fostex T925a Alnico horn tweeters with first order high pass crossovers
REW, I know you well.
Phil A
« Reply #3 on: 21 Jul 2025, 07:38 pm »
Welcome - thx for sharing!
