0 Members and 1 Guest are viewing this topic. Read 3550 times.
regardless of whether or not bridging an amp makes it sound better or worse (my personal opinion is that it will usually make it sound worse, but it waries, from amp to amp), you should not be bridging in your situation. why? cuz for best subwoofing, stereo subs are required. run one sub on the right channel, the other on the left channel...doug s.
Quote from: doug s.regardless of whether or not bridging an amp makes it sound better or worse (my personal opinion is that it will usually make it sound worse, but it waries, from amp to amp), you should not be bridging in your situation. why? cuz for best subwoofing, stereo subs are required. run one sub on the right channel, the other on the left channel...doug s.Some day I'll pick up a stereo crossover (or another x-30) and try that, thanks.
For your eBay pleasure... a Paradigm X-30.http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=5776956336&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
Well... how did it end up sounding?& did the same size subs end up bumping into each other? (the reason the Larger has different sizeddrivers :>) pc
