Dodd battery Preamp
0 Members and 1 Guest are viewing this topic. Read 7708 times.
this_is_vv
Dodd battery Preamp
« on: 27 May 2025, 11:10 pm »
By some stroke of luck i got hold of Dodd preamp/ buffer. Issue is the friend lost the remote and all the cables. I am trying to figure out how to get it working. I am planning to get
https://www.amazon.com/CTEK-40-206-5-0-12-Battery-Charger/dp/B00CD44RQO
for battery i am getting
https://www.amazon.com/Rechargeable-Emergency-Lighting-Security-Terminals/dp/B0180YUC00?th=1
I am still confused how will i connect the batter to the preamp , i know i need to buy some powercon connector
https://www.amazon.com/NEUTRIK-NAC3FXXA-W-L-POWERCON-Power-Locking/dp/B0CQ68NHGY
I am just confused how all this will come together. Like charger and split the cable etc. Any ideas or someone have anything lying around?
Re: Dodd battery Preamp
« Reply #1 on: 28 May 2025, 03:39 am »
Must be noted that DC Voltage is polarized, you must connect the positive battery terminal to the input marked as positive on the equipment.
If connected in reverse, will occur damage to the pre-amp and the battery may heat up.
yamaha626
« Reply #2 on: 28 May 2025, 11:32 am »
I would reach out to GR Research. I know that they have a good deal of experience with the Dodd products. I saw a video on youtube where Danny highlighted his Dodd components.
ZAKski288
« Reply #3 on: 1 Jun 2025, 03:37 am »
This is how it is hooked up.
On my Dodd preamp I now use a linear power supply. Good luck
this_is_vv
« Reply #4 on: 9 Jun 2025, 08:16 am »
What linear power supply you recommend ?
ZAKski288
« Reply #5 on: 13 Jun 2025, 05:14 am »
This is one choice
Link: https://www.dxengineering.com/parts/asr-sl-11r
The one I purchased was on Ali Express is no longer coming up, but  this one is similar 12v/2.5A, 30watts
I just found this on AliExpress: $98.35 | STUDER 900 R-Core Linear power supply For Preamplifier/DAC DC 5--24V (Optional)
https://a.aliexpress.com/_msD2GFV
You will still need fabricate the power cord from the linear power supply to the preamp. Good luck
Jon L
« Reply #6 on: 14 Jun 2025, 05:25 pm »
Is there a switch to cut off the charger when using the preamp, or do you have to physically unplug the charger?
ZAKski288
« Reply #7 on: 17 Jun 2025, 04:15 am »
Yes, you have to physically unplug the charger.
maxima95
« Reply #8 on: 17 Jun 2025, 03:45 pm »
I have had a Dodd Buffer for a long time and have used it sparingly.
I did not unplug the charger when I used it (it never occurred to me to do so).
How long can (should) you play it unplugged?
I take it that it sounds better unplugged.
Thanks for any info on this.
ZAKski288
« Reply #9 on: 17 Jun 2025, 10:11 pm »
You can play it while it charges, but after it’s fully charger it doesn’t make sense to leave it plugged in and charging. Better to cycle the battery. When I used the battery only, it would last a long time before it died. Then I would charge it till it was fully charged.
maxima95
« Reply #10 on: 19 Jun 2025, 01:33 pm »
Thanks for responding.
