Maggie Bass
0 Members and 1 Guest are viewing this topic. Read 7061 times.
SteveFord
Maggie Bass
« on: 23 Mar 2025, 05:08 pm »
The intrepid Wendell Diller has been busy.
It looks like there's a new project coming up, this looks really interesting.
https://www.maggiebass.com/
Jon L
Re: Maggie Bass
« Reply #1 on: 23 Mar 2025, 11:27 pm »
"The MaggieBASS™ integration system is incorporated exclusively within Danville's DSP to form a system approach to more and better bass."
Finally  :scratch:
SteveFord
Re: Maggie Bass
« Reply #2 on: 23 Mar 2025, 11:51 pm »
I'm going to have to hit up one of the tour dates, I want to hear this one.
Saturn94
Re: Maggie Bass
« Reply #3 on: 24 Mar 2025, 12:22 am »
Isn’t this pretty much the bass unit Magnepan has been touting for years but never released?  Any indication it will finally be released, or is this just more “show”?
PS - When was that written/posted?
SteveFord
Re: Maggie Bass
« Reply #4 on: 24 Mar 2025, 12:55 am »
It was sent to me this morning.
I don't know if the sides make any difference to the sound but I'd prefer the wood finish to match my speakers.
I'll post new developments as I get them.
BikeFi10
Re: Maggie Bass
« Reply #5 on: 1 Apr 2025, 06:17 pm »
I agree with Steve wood sides would look much better. These look like a granite counter store's idea of built in counter speakers for a kitchen.
For my 1.7i s, I use a custom downfire Rythmik F12 servo drive sub. It seems to do quite well, but If budget permitted GR Research Double Trouble open baffle subs would be my go to. Dont know for sure, but probably more affordable then the Maggie sub.
I.Greyhound Fan
Re: Maggie Bass
« Reply #6 on: 1 Apr 2025, 07:12 pm »
Add a second Rythmik.  I use dual Martin Logan subs and the second sub just increased the depth and width of the sound stage.   I also own a RythmiK F12se.  It is a great sub.
HAL
Re: Maggie Bass
« Reply #7 on: 1 Apr 2025, 07:39 pm »
The website changed:
https://www.planarbass.com/
SteveFord
Re: Maggie Bass
« Reply #8 on: 10 Sep 2025, 01:49 pm »
Dear Press Member,
From Wendell a few minutes ago:
A press report from Axpona described the PlanarBASS as a "kit". Some individuals thought that PlanarBASS came stock with quartzite side panels. Perhaps the confusion is due to the unique cosmetic design feature of the PlanarBASS.
The analogy of the working relationship between a custom cabinet maker and the custom countertop maker might help. Diller Designs will ensure that the customer gets exactly what they want-- solid wood, stone, glass or metal (even a piece of plywood painted with a spray can if the customer insists).
My intention for this unique design concept was to give the "Interior Designer" more freedom to integrate the PlanarBASS into the decor of the home.
planarbass.com
