0 Members and 1 Guest are viewing this topic. Read 5680 times.
If you are using the Golden ratio of 1 x 1.6 x 2.56 where it goes like this (Height, Width, Length) then you are looking at a height of 9.3751 x is height 1.6 x is width2.56 x is lengthDon’t waste your money on corner treatments, the corners are a tiny fraction of your problem. The whole wall is a bigger problem, look into addressing a bigger part of the wall’s rather than a tiny corner which will do very little audio difference.You have a fairly big-ish room, look to getting your speakers well away from the room boundaries and you will find you’ll need less treatment.My speakers sit almost 7 feet from the front walls and over 3 feet from the side walls, I have less room boundary interference. Even though my front and rear wall are treated with quadratic diffusors, I only really need to pay attention to the floor and ceiling as those are the closest and smallest distances.If you click on my systems profile on the left, you will see my room. The room sounds great and I have not done too much to it.
...more air volume to be moved.
I’m in transitional situation right now because of the LA fires. Don’t know what system I’ll end up with and budget after rebuild. Just trying to think ahead and keep my mind on something pleasant But, most likely monitors and a sub.
Those plants must act like nice diffusers. I always wanted to try that but could never figure out the light situation.
