Tube Sockets
0 Members and 1 Guest are viewing this topic. Read 2141 times.
viggen
Tube Sockets
« on: 17 Feb 2025, 07:13 pm »
Hello.
I am need of replacing a pair of tube sockets for 6922 tubes.  So, I am in the market for a pair.  Never had to buy them before.  So, not understanding what to look out for.
I found this cheap one:  https://tinyurl.com/vigenn
And, this pricier one: https://tinyurl.com/yxwnsbbk
Do they make any diff?
Thanks.
nlitworld
Re: Tube Sockets
« Reply #1 on: 17 Feb 2025, 08:20 pm »
Belton 9-pin
These are the ones I just picked up for an amp build. The basics will work, but you don't get rid of the full audiophile paranoia til you go above and beyond. The idea best I can tell is that microphonic tubes can sound different with ceramic vs different socket material if they were to catch some extra vibrations. Also looking at the metals used in the pins will make the most difference. I wish I could have found pure copper pins, but best I could find were gold coated bronze. Gold is better conductor than bronze, so I'd suggest a splurge there. Also tight fit pin holes is actually a good thing. Most DIY forums kept recommending these so I decided to give it a go.
Other thing you'll need to check is if they go to a PCB mount or point to point wiring surface mount.
JakeJ
Re: Tube Sockets
« Reply #2 on: 17 Feb 2025, 08:25 pm »
The main difference between the two you linked is the less expensive ones (Amazon) are PCB mount and the more expensive ones (eBay) are chassis mount.  The common thread is they are both ceramic with gold plated contacts which is nice.
What is the project?
Oops!  I'm late.  Also I was wrong they are not both ceramic, the Amazon ones are and the eBay ones are teflon.  I have never had any gear with teflon sockets.
Re: Tube Sockets
« Reply #3 on: 17 Feb 2025, 08:31 pm »
Hello.
Thanks.
Always use Teflon sockets for small tubes.
They offer better sound, decrease microphonics, if there is it in the tube, they really worth the price.
« Last Edit: 18 Feb 2025, 04:13 am by FullRangeMan »
JakeJ
Re: Tube Sockets
« Reply #4 on: 17 Feb 2025, 09:17 pm »
Always use Teflon sockets for small tubes,
They offer better sound decrease microphonics if there is it in the tube, they really worth the price.
Learn something new everyday.  I searched this topic and found several forum threads supporting this.  More than one DIYer find a positive result when a ceramic socket is replaced by a teflon one.
viggen
Re: Tube Sockets
« Reply #5 on: 17 Feb 2025, 09:21 pm »
Thanks everyone!  This will be PCB mount for a dac, Kora Hermes, with tube output.
