Inductor placement
0 Members and 1 Guest are viewing this topic. Read 1743 times.
Kiwiaudio
Inductor placement
« on: 19 Jan 2025, 03:34 pm »
First post. My apologies for having been a lurker for a long time. I recently tore down a pair of speakers i put together 35 years ago and removed these crossovers. They were made for me by a company that shall remain nameless, and i intend to reuse them. After reading Dannys technical inductor page, i see the big nono inductor placement errors. Im thinking about just turning the 2nd and 4th coils sideways to obtain placement #7 in Dannys picture. What do you think ?
Cut-Throat
Re: Inductor placement
« Reply #1 on: 19 Jan 2025, 05:35 pm »
I've usually followed charts like these.  It looks like whoever built your crossover did not spend any time researching Inductor Placement.
Kiwiaudio
« Reply #2 on: 19 Jan 2025, 06:54 pm »
Agreed. I read an old adage somewhere If you can look through the hole of a coil and not see another coil, then you are ok
The builder must have subscribed to this theory.
So, i should move a couple of them ?
corndog71
  • Some people call me Rob.
« Reply #3 on: 19 Jan 2025, 07:00 pm »
Yep, there are videos on you tube that show how much orientation can change the measured inductance.  That chart is accurate.
richidoo
« Reply #4 on: 20 Jan 2025, 03:10 pm »
S Clark
« Reply #5 on: 20 Jan 2025, 04:01 pm »
Quote from: Kiwiaudio link=topic=191149.msg1999810#m sg1999810 date=1737312881
I'd move the top one and the 3.0 mH one using the orientation of #6 on the chart.
