To wool or not to wool
0 Members and 1 Guest are viewing this topic. Read 3318 times.
BazzaR
« on: 3 Jan 2025, 03:50 am »
As I'm a newbie to the site I still can't search the treads yet unfortunately, so sorry if this has already been talked about.
About three weeks ago I finished building a pair of X-Statix's, and after about 150hrs they're starting to sound amazing.
My question is, although I've lined the inside with NoRes, would the cabinets benifit from addition sheeps wool being inserted?
Cheers
Barry
Danny Richie
Re: To wool or not to wool
« Reply #1 on: 6 Jan 2025, 08:46 pm »
Cheers
Barry
After lining them with No Rez I added some loose fiberglass insulation.
PumaCat
« Reply #2 on: 6 Jan 2025, 09:00 pm »
That's also what used when building up my Encores after affixing the NoRes.
Just a tip: if you use fiberglass insulation, be sure to wear some latex or vinyl disposable gloves so you don't get the glass fibers from the fiberglass into your skin.
« Reply #3 on: 6 Jan 2025, 09:01 pm »
Cheers
Barry
Its a personal taste matter, inform us your opinion after this mod.
« Reply #4 on: 6 Jan 2025, 09:03 pm »
Or lungs.
PumaCat
« Reply #5 on: 6 Jan 2025, 11:18 pm »
Or lungs.
Exactly right, good point. Good to wear a mask while adding it, as well. :thumb:
BazzaR
« Reply #6 on: 7 Jan 2025, 07:13 am »
Awesome, thanks Danny. I'll give it a try, however it will be with real sheeps wool not fiberglass.
BazzaR
« Reply #7 on: 7 Jan 2025, 07:15 am »
Appreciate the concern, I'm going to be using real sheeps wool. Something I have access to in abundance  :D
BazzaR
« Reply #8 on: 7 Jan 2025, 07:16 am »
Will do  :thumb:
Rocket_Ronny
    • ScriptureSongs.com
« Reply #9 on: 7 Jan 2025, 05:18 pm »
I have had speakers using sheep's wool. Seemed to work fine. Just keep it fluffy and not over stuffed of course. I would prefer that to fibreglass any day.
Rocket Ronny
VinceT
« Reply #10 on: 8 Jan 2025, 02:24 pm »
Interesting, I don't think my Encores or LS9'S have any fiberglass/wool. Sounds like that is recommended.
PumaCat
« Reply #11 on: 9 Jan 2025, 04:35 am »
I used fiberglass per Danny's recommendation when assembling my Encores, just for reference.
Cheers.
VinceT
« Reply #12 on: 14 Jan 2025, 02:24 pm »
I have the old AV123 LS9s. At some point they will need some attention and I will do the no rez install, is it recommended that poly fill or fiberglass also be installed in this model?
