triple sub plate amp died
0 Members and 1 Guest are viewing this topic. Read 1597 times.
cynadon
« on: 23 Dec 2024, 06:43 pm »
A370PEQ plate amp. Triple sub / middle reversed. Subs play when I disconnect servos. Don't find any shorts on the speaker end. Donesn't seem to have output at amp. I don't see any magic smoke marks, solder, swells, cracks or anything. I haven't had time to probe with the scope yet. I was wondering if anybody has had to replace  the servo board? part #081073042
jason
[email protected]
TRADERXFAN
  • Trillions will vanish... it's a debt blackhole.
    • GALLERY
Re: triple sub plate amp died
« Reply #1 on: 23 Dec 2024, 08:46 pm »
Not had to replace, but I did get a swap for a different servo board with a different slope from Brian at Rythmik. they are a little socket board that you can disconnect. Do you have a pair of these or a single set? if a pair you might swap the good one out for it and see if that fixes it.
cynadon
« Reply #2 on: 24 Dec 2024, 12:50 am »
No I have only one speaker/amp.  I probed around with my oscope a little. I dont get anything from the pins of the ribbon connector
HAL
« Reply #3 on: 24 Dec 2024, 04:12 pm »
Were the servo sub working earlier, or is this their first startup?
Danny Richie
« Reply #4 on: 24 Dec 2024, 07:51 pm »
If you can't get it figured out then contact Brian and Rythmik Audio and he will help you get it sorted our or will replace it.
jmimac351
« Reply #5 on: 1 Jan 2025, 04:01 am »
I had one of these fail on an F8 amp (HX580) and was able to get in touch with Brian before the holidays.  He sent a document over to remove the amp properly, wiring, etc.  Let me know if you need it.
If you look on his site, his number ends in 3712.
Nick B
« Reply #6 on: 1 Jan 2025, 07:41 am »
Had an issue with a Rythmik sub and Brian took care of it very quickly. Great service and turn around time as I was unable to remove the board
