Copper Ribbon Speaker Wire from AliExpress
0 Members and 1 Guest are viewing this topic. Read 715 times.
Bekay3
« on: 12 Dec 2024, 09:08 pm »
Just shipped my first return to China. I wanted to evaluate a knock off of the Nordost Valhalla style cable. The wire was terminated with shrink wrap so I couldn't dissect it without damaging. Seemed well done from the outside. Appearance was as pictured. No complaints. Sound was a bit disappointing. What at first sounded like a wider soundstage revealed itself as a phase disorder. It got annoying. There seemed to be adequate clarity but the balance was U shaped with a decreased weight to vocals and especially the woody resonance of the cello. Overall a big step below my DIY Jon Risch speaker cables. They are going back.
Returns was easy. Answer a couple question and they send you a printable USPS prepaid label for the package.
Re: Copper Ribbon Speaker Wire from AliExpress
« Reply #1 on: 12 Dec 2024, 09:54 pm »
How much do you paid?
cheesey
« Reply #2 on: 13 Dec 2024, 12:32 am »
Are all of these "flaws" subjective assessments or did you do a before and after frequency sweep to verify the changes?
