Tube Conector Installation Pictures?
0 Members and 1 Guest are viewing this topic. Read 2197 times.
melchionda
« on: 17 Nov 2024, 08:09 pm »
Hi, I'm about to install my third set of tube connectors.  I've made a mess out of the first two.  I watched Danny's video a bunch of times on YouTube but you really cant see whats going on on the tube connector during the install because the camera is too far away.  Does anyone have any photos of what the crip and the subsequent solder in-fill looks like when its done correctly?  Like I said. Mine was a mess and I can't imagine that what I did was the intended result.
KTS
Re: Tube Conector Installation Pictures?
« Reply #1 on: 17 Nov 2024, 09:29 pm »
I wish I did, I am always too excited when I get to that point of the build to take pictures. I did have a helpful forum member suggest that I clip a small piece of stripped speaker wire and put it into the tube connector with the wire from the crossover, it is small diameter wire compared to the opening of the tube connector. That did help a lot with the end results, at least it looked better. As long as you get good contact with the wire and the wall of the tube connector prior to soldering you should be good. Just my experience.
jmimac351
« Reply #2 on: 17 Nov 2024, 09:31 pm »
melchionda
« Reply #3 on: 23 Nov 2024, 06:24 pm »
Thats a good idea.  So add an extra piece of crossover wire to better fill the tube. I will try that.
I also just purchased a hexagonal crimper off of Amazon.  It was like $16.  I'm going to play around with that to see if I can get a cleaner crimp.
melchionda
« Reply #4 on: 23 Nov 2024, 06:28 pm »
See here for pictures of how to crimp, etc.
https://www.audiocircle.com/index.php?topic=94014.msg1958805#msg1958805
Thats what I was looking for.  Thanks!
E-Zee
    • Diy speaker resources and crossover assembly services
« Reply #5 on: 4 Dec 2024, 02:10 am »
Often there may be many correct methods that work so I'm not implying mine is ideal or better than someone else's but it is what has worked for me and others i have suggested it to.
  I have not had to use a crimping tool but what has worked is to twist one or even two small 1" or even 1.5" long bare wire scraps to the end of your wire. I've used the same 16ga wire and just cut a couple scraps from it. After twisting together, trim the ends flush, and that larger diameter will fill up the inside of the tube connector more precisely so that it doesn't have to be cramped to the point of mangling. It's easier for me to solder as there will be more wire contacting the inside wall and less gap getting possibly filled with solder. It also gives more surface contact against the tip of the male tube connector.
If I recall correctly the one piece of 16ga wire plus 2 more 16ga scrap pieces fills up the space fully, but even one scrap piece (2x 16ga total) let's it be crimped with much less effort. Just play with it and see what fits, but the idea is to fill up the space with more then the one wire. More surface area contact, less crimp required,  more tip to tip contact with the connector.
