Polk L200 Best Speaker Stand
0 Members and 1 Guest are viewing this topic. Read 1428 times.
TL13506
« on: 8 Nov 2024, 01:56 am »
Hi everyone! I'm new to the forum and need some advice on good, affordable speaker stands for the Polk L200.
Re: Polk L200 Best Speaker Stand
« Reply #1 on: 8 Nov 2024, 10:17 am »
Welcome to AC  :thumb:
sonicxtc
« Reply #3 on: 8 Nov 2024, 01:58 pm »
Solid steel ss series...look for used.
https://www.reddit.com/r/BudgetAudiophile/comments/113nga6/any_suggestions_for_solid_steel_style_stands_at/
https://www.norstone-design.com/pieds-d-enceintes Some interesting ideas
Use a tripod shaped bar stool, cut the legs to whatever height you need
Build your own with plywood base, smaller top plate and 2 x 4 or 2 x 6s. I did this years ago and it's easy.
Good luck and let us know what you decided.
js1955
« Reply #4 on: 8 Nov 2024, 04:58 pm »
If looks aren't important, stack cinder blocks.  As rigid / solid as it gets.
TL13506
« Reply #5 on: 9 Nov 2024, 12:02 am »
Thanks for all your suggestions! I'll update everyone on my decision once I've made it.
« Reply #6 on: 9 Nov 2024, 02:05 am »
Greetings & Welcome to AC   :thumb:
