My take on the X-LS Encore
0 Members and 1 Guest are viewing this topic. Read 7607 times.
johnwoitalla
Re: My take on the X-LS Encore
« Reply #20 on: 31 Jan 2025, 03:47 am »
The finish is beautiful and very rich looking on your boxes. I also really like those stands, did you make them too?
Komoyuki
« Reply #21 on: 31 Jan 2025, 12:48 pm »
No, these are the Kanto SX26 filled with cat litter
rfluongo
« Reply #22 on: 31 Jan 2025, 01:04 pm »
Your room also looks great. Enjoy the music!
Komoyuki
« Reply #23 on: 5 Feb 2025, 06:11 pm »
I must say that it is by far the speakers that respond the most to the break-in period. about 45-50 hours actually and the scale and bass have woken up so much. It was indeed light at first, and I told myself that it was normal, it's a monitor. But phew, in my room they begin to fill it with authority.
Great bookshelf for sure !!
« Last Edit: 5 Feb 2025, 09:39 pm by Komoyuki »
Hobbsmeerkat
« Reply #24 on: 5 Feb 2025, 09:37 pm »
Our drivers really need that initial break-in period of ~50Hrs. Then depending on the crossover parts, they should continue to open up over the next ~50-150hrs
jmimac351
« Reply #25 on: 5 Feb 2025, 10:54 pm »
I had a good experience with this regarding a different speaker, but with 2 different sets of crossovers with the exact same parts. A friend and I own the same speakers and had revised crossovers made for them.  I had both sets of crossovers. He isn't local and he wanted me to play with the setup.
I listen every day, quite a bit.  I think it was over the course of about a month that it just kept getting better and better... I was telling him it just kept getting better.  He finally came to listen / get his crossovers.  Yes... I gave him the burned in crossovers.
Then, the second set went in with fresh parts.  I had a direct comparison, and it just was not the same.  The "magic" wasn't there... or at least a lot less of it.  I told myself the same thing... "these will break in too".
150...200...400hrs...the caps are Sonicap on the tweeter and JB JFX on the woofer.  (The JB JFX are really good)
Have fun.
Komoyuki
« Reply #26 on: 7 Feb 2025, 06:27 pm »
« Reply #27 on: 7 Feb 2025, 06:30 pm »
Great speakers and great space.
PumaCat
« Reply #28 on: 8 Feb 2025, 10:08 pm »
Lovely space. Nice to see that you have some acoustical panels on the front walls. It also appears your speaker cables are not placed on the floor, which is also really helpful for the audio quality of a system.
As a photographer, I also like the photographs on the front wall, and something I also noticed is the quality of light in your room is very nice, as well. Enjoy.
