-SOLD- tubes4hif ST35 EL84 with lots of updates lowered 700$
0 Members and 1 Guest are viewing this topic. Read 975 times.
chitlins-parmigiana
ST35 EL84 Based Tube Amplifier
SOLD
This is a 17 watt per channel, push-pull EL84 tube amplifier which was built and tested by tubes4hifi.com. Larger chassis size of 16W x 12D x 4H helps it run cooler than the smaller version.
The ST35 comes with both 8 ohm and 4 ohm speaker terminals. Purchased the amp from the original Buyer and had Mike Galusha look over the amp and install some changes.
The coupling caps are Jantzen Audio Silver Z--Caps matched with in 2%
I discussed the best way to take the cheaper gold plated binding post out and to install all new post ,he said a plate would have to be cut-so too expensive. I had on hand 2 pairs of cardas Rhodium binding post and asked would they fit , they did fit and improved sound above the cheaper post on the 8 ohm tap.The 4 ohm tap will share half of the new binding post, a bit unorthodox ,but sure worked out great !Amp has minor scratches on the chasses that are common with this type of amp , the face looks great
IeGo pure silver IEC
inputs are Gaofei Rhodium pure copper
fuse holder is acme silver coated cyro
Hi--Fi Tuning Supreme silber/Gold fuse
He rewired the input using silver ,copper telfon and from the IEC
https://www.tubes4hifi.com/ST35.htm
ECF Sylvania pre tubes NOS
Matched quad Preferred Series 7189 Premium EL84 Power Vacuum Tube, thetubestore.com ,My estimate on tubes and amp is around 250 hours , all still practically NEW
Outstanding sound !, have too many amps
 As good as this deal will get 700$ and split shipping  FNF OR Zelle can discuss shipping arrangements
$ FNF Or Zelle .S&H is paid for by buyer
« Last Edit: 7 Jan 2025, 12:25 am by chitlins-parmigiana »
nlitworld
Re: ST35 EL84 with lots of updates, 2 years old
« Reply #1 on: 10 Oct 2024, 03:01 pm »
Wish I would have seen this a month ago. I just bought parts to build one myself completely decked out to the 9s. I'm sure this amp sounds fantastic with those upgrades. The Tubes4HiFi kits really give a huge value and very accepting of upgrades for even more performance. GLWTS!
chitlins-parmigiana
« Reply #2 on: 10 Oct 2024, 09:10 pm »
Thanks nlitworld !
Its a nice sounding amp, May decide just to put it on a shelf for now . Will see
