0 Members and 1 Guest are viewing this topic. Read 7699 times.
In my experience Odyssey amps don't produce a lot of heat.??
It's blowing up. Thanks
Would it not make more sense to put the power-amp on top and your problem of heat rising goes away.
The preamp gets warmer than the amp though.
Based on my (visibly the same as yours) preamp that sits by itself on the shelf and never gets warm, my guess is that any warmth you feel from your preamp is being generated by the amp underneath it. It would seem odd to have an amp on top - for whatever reason, we always see the preamp on top) but that'd be something to toy with. But I'm with the other posters who suggest some sort of risers would do the trick, and if your fan is quiet enough you could position that to draw air from between the two units.
Okay I see now, it’s a valve pre. Are you able to move the plant and the vase off the sideboard, so you can put the Pre & Power next to each other?
My Pass Labs XA25 is Class A and runs hot. I called Pass Labs, and they said that I should be able to hold my hand on the top for a few seconds without feeling like I'm getting burned. It was running at about 120 °F, which was ok according to Pass Labs.It could be apples and oranges, but maybe it helps.Here's what I measured:
Brilliant! Take the heat generated by the amplifier and suck it through the preamp so it can be hot too!
I think why this preamp gets warmer than the amp is because it has tubes in it.
