What to use?
0 Members and 1 Guest are viewing this topic. Read 2463 times.
serlvz
What to use?
« on: 13 Jul 2024, 04:40 am »
Left a couple of batteries in a remote for a device I hadn't used in a long while. What can I use to clean up corrosion in the small ( 2 AAAs ) battery compartment. There is not a massive amount, but still, I'd like to get it as clean as possible. I was able to scrape a bit off the contacts with an Exacto knife, but I need to know what I can put on a small brush to get the rest off.
Never did take chemistry ( damnit! ), so I haven't a clue.
Scott
ctviggen
Re: What to use?
« Reply #1 on: 13 Jul 2024, 11:27 am »
I can't help, but I'm interested too.  I have a gas fireplace insert that uses 4 AA batteries for emergency mode when it has no power.  I accidentally left the batteries in there, and now one of the contacts is corroded.  I thought I cleaned it, but during the last power outage, I put new batteries and it did not work. I had to turn on the power to the insert, and every watt counts when running a small gas generator on a large house.
Phil A
Re: What to use?
« Reply #2 on: 13 Jul 2024, 11:52 am »
https://www.youtube.com/watch?v=z7ihHyBwyRU     -  I've used baking soda and water too besides what is in the video
serlvz
Re: What to use?
« Reply #3 on: 14 Jul 2024, 06:24 am »
Thank you, Phil
