Digikey Parts Number question for Cornet
0 Members and 1 Guest are viewing this topic. Read 1593 times.
fishydan
« on: 12 May 2005, 01:01 am »
Hello-
I am rounding up the parts for my Cornet 2, and punched up Digikey part # P11423CT-ND, from the parts list, and it came up as a 250V ceramic cap.  But the description in the parts list is a 2kV cap.  Mouser has a Wima  MKP10 with the specified voltage.  Should I go for that?
Dan
hagtech
« Reply #1 on: 12 May 2005, 03:02 am »
Yeah, that's the ac rating.  Special cap made for 125Vac or 250Vac across the power line applications.  Also handles 2kV or something like that at dc.
jh :)
fishydan
Any alternate source?
« Reply #2 on: 12 May 2005, 03:18 am »
hello Jim-
Digikey is back ordered on that one and the 470uf 10v until July!!!
Any other sources?
Dan
hagtech
« Reply #3 on: 13 May 2005, 01:06 am »
Switch to the 4.7nF value.  I think that one is in stock.  This cap is just for noise reduction, value not critical.
They also have other 470uF caps from other manufacturers.  Their online search works well to narrow down.  Type in 470uF and then whittle through the choices to select another part number.  They sell a dozen versions of this value cap.
jh :)
