Solder or Tube Connectors
0 Members and 1 Guest are viewing this topic. Read 2177 times.
BrandonB
« on: 12 Jun 2024, 01:11 am »
How close is the quality of connection of aTube connector connection to a solder joint.  I was thinking of connecting my crossovers to the driver wire with tube connectors instead of solder so I can disconnect quickly without issue.
KTS
Re: Solder or Tube Connectors
« Reply #1 on: 12 Jun 2024, 10:37 am »
That is a great question, I would suggest leave enough wire to cut and install the tube connector, but try point to point at first. After you run them in try the tube connectors to see if you notice a difference. I don’t believe it would be noticeable because the tube connectors are low mass and good quality, but I have not attempted that configuration. Good luck!
Early B.
« Reply #2 on: 12 Jun 2024, 12:48 pm »
I think the benefit of disconnecting quickly overrides any connection quality concerns vs. soldering.
richidoo
« Reply #3 on: 12 Jun 2024, 01:30 pm »
^ I agree, as long as your connectors are copper, or plated copper like tubeconnectors.
There is always some micro-arcing with any temporary connection, but you can eliminate that with contact enhancer.
MCT oil (or pure caprylic acid) is cheep and cheerful contact enhancer.
S Clark
« Reply #4 on: 12 Jun 2024, 03:39 pm »
Why not twist wires with needle nose, apply thin coat of dialectric grease, and cap with an all plastic wire nut?  Copper to copper connection, tighter than push in types, easily removed, very low cost.  Win, Win, Win, Win.
BrandonB
« Reply #5 on: 13 Jun 2024, 03:08 am »
MCT oil for my Keto and speaker wires  :lol:
BrandonB
« Reply #6 on: 13 Jun 2024, 03:10 am »
That's cheap and a good idea!
Scott Joplin
« Reply #7 on: 13 Jun 2024, 10:11 am »
^ The next stage up would be wire wrap
jmimac351
« Reply #8 on: 13 Jun 2024, 02:14 pm »
If you're not certain you will be swapping any crossover parts out, I would solder the output leads directly, with some shrink wrap.  Look at the length you have coming out of the crossover... leave them long like that.  Leave some length for the driver wire hookups down at the crossover as well.  If you "must" remove the crossover, you will have enough length of wire for both the crossover output - driver input wire to snip / solder many times.
What's the realistic scenario for R&R the crossover routinely?
The Otica crossover has too many parts for "playing with parts" activity, except maybe fooling with the tweeter cap.  But for that speaker, even in that case, it should get the best parts one is willing to pay for from the very beginning, such that there is no itch to "upgrade" parts down the road. Even if you do want to try something for the tweeter in place of that Sonicap, if you leave the wires long enough, you can slide the crossover out far enough to work on it.  That's how I'd do it.
BrandonB
« Reply #9 on: 13 Jun 2024, 03:44 pm »
I have great parts but eventually may upgrade.
