PMC AB2 monitors
0 Members and 1 Guest are viewing this topic. Read 5144 times.
gelmhirst
PMC AB2 monitors
« on: 4 May 2005, 12:10 am »
I rarely see AB2s in use, any reason? I am seriously considering the AB2s as an upgrade from my 3 day old previously enjoyed TB2s... anyone have any experience with these magnificent beasts?
Fife12
PMC AB2 monitors
« Reply #1 on: 4 May 2005, 01:55 am »
The AB2 will be a significant upgrade!
The large Dynaudio driver wont be easy to drive though.
gelmhirst
PMC AB2 monitors
« Reply #2 on: 5 May 2005, 12:03 am »
Does anyone know what the AB2s are priced at approx? I think I've seen 5k..
  • The Demo is Everything!
    • http://www.bryston.com
PMC AB2 monitors
« Reply #3 on: 5 May 2005, 12:16 am »
$4395 US a pair - only now available in S finish.
james
gaderson
PMC AB2 monitors
« Reply #4 on: 5 May 2005, 04:49 am »
Quote from: Fife12
Yes, you'd want at least a 4B.  I have the dynaudioacoustic BM15s passive monitors that I believe are the same driver compliment (same woofer, and similar <8 Ohm impedence).  And, I first powered them with two channels of my 9B-ST.  It wasn't untill I got a 4B-ST-Pro that they really came into their own.  (But, I'm now enjoying a pair of DB1Ss much more--smoother bass extension, absolutely hooked on (quasi-)transmission line loading.)
gelmhirst
AB1s instead
« Reply #5 on: 24 Jul 2005, 08:07 pm »
I have bought a used pr of AB1s instead, anyone know how long PMC has been using Dynaudio drivers in the AB1, AB2 or even the OB1s.
I can't pinpoint the age of this pair until I see the serial #, and the dealer thinks 3 years old, I think older. I am hoping for the Dyn drivers.
PMC AB2 monitors
« Reply #6 on: 24 Jul 2005, 08:18 pm »
HI,
The original AB1 used a Dyn tweeter and Dyn woofer - the next version used a Fifa tweeter and Dyn woofer.
I would say the AB1 was replaced with the AB2 about 5 years ago.
james
gelmhirst
thanks James
« Reply #7 on: 13 Aug 2005, 02:49 pm »
The AB1s are outstanding. I can not believe the sound of these coupled with my 3BST, and then fed with my AZ Hologram, absolutely amazing. I do not know the age of these, ser#002529 & 002530, the Dyn drivers are a dream come true.
