rca shc 663 tube 3 channel amplifier problem , base channel speaker oscillates .
0 Members and 1 Guest are viewing this topic. Read 1567 times.
filamenthead
hello !  i am new at this site  !   i need help  with an rca tube amp.  the amp i have is a three channel amplifier running on the 6bq5  in p.p.   ,  the 3rd. channel is supposed to be for  the base .  both left and right channels work and sound great , but  the base channel  i cannot figure out how to make it work properly ,  when i power it up  after a minute or so  the woofer oscillates and goes in out like crazy  but no sound can be heard ,  this happens even when no signal is applied .
i changed coupling capacitors , power suply electrolytics caps , all resistors , i even installed new tube sockets , also tried with another output transformer , removed all components and re installed fresh new ones and still i get severe oscilation on the base speaker , with or without a signal .
can anybody out there help  !  :duh:
After the equipment warmup the circuit starts oscillate.  :scratch:
I had this problem in an SS pre-amp, it was a low quality diode that worked well with a light load, but with 4 ohms speaker it started to show treble noises. Also could be cold welding or some component in the PS.
More related info:
https://www.diyaudio.com/community/threads/oscillation-in-tube-amps.145103/
richidoo
Time to bring in a pro, if you can find one. In which city do you live?
https://www.audiocircle.com/index.php?topic=90988.40
Search the whole forum for other threads about repair techs.
