WTB/ISO Finger Lift for the SME Series IV -- Found!
0 Members and 1 Guest are viewing this topic. Read 1157 times.
JakeJ
« on: 18 Oct 2023, 05:20 pm »
I bought an SME Series IV but it didn't include the finger lift and two spacers/washers it came with.  Ifound a company in GB that makes a copy but they are charging over fifty bucks US plus VAT.  I'm looking for someone who might have a spare or knows of another source.
TIA
Jake
« Last Edit: 25 Oct 2023, 08:06 pm by JakeJ »
js1955
JakeJ
Re: WTB/ISO Finger Lift for the SME Series IV
« Reply #2 on: 19 Oct 2023, 04:36 pm »
Hello and thanks for the link.  I did see those on eBay, I would prefer one in bare metal (silver) to match the tonearm but the main issue is they do not include the necessary spacers/washers the lie in recesses under the finger lift.  Also found a company in England that offers an exact replica but it's $50+.  I'm a cheap audiophile so I have been thinking about making one from bamboo.
I'm looking locally for the spacer/washers but the exact size is uncommon.  It appears a 2.5mm flat washer is it but I have to find some.  If I find the correct size then I might buy a black one and switch it with the silver one on my M2-9 arm.  I can't just steal the one off the M2-9 because once the Series IV is installed I want to sell the M2-9.
On a positive note I did hear back from the original seller and he is looking for the one that came with it.  The price on that one is just right!  :wink:
JakeJ
« Reply #4 on: 21 Oct 2023, 05:43 am »
The silver one from eBay will likely be the solution and yes a plastic washer would work as long as it fits in the recess.  Through scouring the web for washers and headshell/cartridge hardware I believe they are washers for a 2.5mm screw.  Of course neither of the sets I ordered on Amazon have that size so I'll go back to the local fastener stores.
Updates forthcoming.
JakeJ
Re: WTB/ISO Finger Lift for the SME Series IV -- Found!
« Reply #5 on: 25 Oct 2023, 08:08 pm »
So I bought the cheapos from an eBay Asian seller.  Will see what the quality is like when they get here.
