How to remove front panels of Sonus Faber Venere 2.5?
0 Members and 1 Guest are viewing this topic. Read 775 times.
Nilswilly
Hi!
My name is Nils, I live in Norway, and I'm new to this forum.
My problem is that I need to remove the front panels and drivers of my SF speakers, in order to make some modifications inside the boxes.
I've unscrewed all the screws holding the panels, but they still seems to be stuck. Can anybody in here help? I'm aware of the video made by GR-Research, but it doesn't tell the "full story".  8)
Best regards Nils
« Last Edit: 12 Jul 2023, 06:53 pm by Nilswilly »
Nilswilly
Re: How to remove front panels of Sonus Faber Venere 2.5?
« Reply #1 on: 11 Jul 2023, 04:03 pm »
Problem solved! The baffle/front panel was stuck as if glued because it actually was glued - by double-sided adhesive tape. I managed to loosen it little by little by a wooden wedge. :icon_lol:
« Last Edit: 12 Jul 2023, 06:32 pm by Nilswilly »
Nilswilly
« Reply #2 on: 11 Jul 2023, 04:05 pm »
« Last Edit: 13 Jul 2023, 12:46 pm by Nilswilly »
adminRH
  • not admin
« Reply #3 on: 11 Jul 2023, 07:17 pm »
Welcome to AudioCircle, Nils!
Now that you solved your problem, I hope you'll "stick around" (haha) with us.
« Reply #4 on: 11 Jul 2023, 10:54 pm »
Welcome tô AC :thumb:
What modifications do you will made inside the Cabinet?
« Reply #5 on: 17 Jul 2023, 02:02 am »
Greetings & Welcome to AC Nils   :thumb:
« Reply #6 on: 17 Jul 2023, 05:54 am »
Hi Nils,
Iam interested in the modifications you will made inside the Vanere enclosure, if possible keep us up to date on this, you could start a topic in the Enclosure Circle.
https://www.audiocircle.com/index.php?board=181.0
Please note this topic on internal enclosure treatments:
https://www.audiocircle.com/index.php?topic=100689.msg1016047#msg1016047
Phil A
« Reply #7 on: 17 Jul 2023, 03:33 pm »
Welcome!
