0 Members and 1 Guest are viewing this topic. Read 5273 times.
Powerd JBL Pro speakers. I was shocked. charles
Which model shocked you?
I've heard these twice now, and each time I was blown away.Buchardt A500
I own the A500SE, slightly above $5k limit. But have also owned the JBL 708P, a wonderful active 2-way using an 8 inch woofer that is under $4k.Actives are very dynamic and produce deep/full bass for the given cabinet size. They can be equipped with EQ and other niceties. For instance the A500SE (an average sized monitor) are rated 25-40,000Hz +/- 1.5 dB.
Magnepan 3.7 used. Magnepan 1.7i, 0.7 and LRS new. Wharfedale Evo 4.4's. Focal Aria's. Monitor Audio Gold 5g 100
You always spend money on the best speakers. But you've only kept one of two pair for the long haul if I recall.. Are you guessing these will be one of the keepers? How's the deep base on these, those movie soundtrack level cuts? Perhaps in comparison to other full rangers you've liked?
1) Klipsch RF-83 used, discontinued.2) Klipsch RF-7 new or used.
