$5K or less speaker thread
0 Members and 1 Guest are viewing this topic. Read 5300 times.
mav52
Re: $5K or less speaker thread
« Reply #20 on: 15 Jul 2023, 01:49 pm »
I own the A500SE, slightly above $5k limit.  But have also owned the JBL 708P, a wonderful active 2-way using an 8 inch woofer that is under $4k.
Actives are very dynamic and produce deep/full bass for the given cabinet size.  They can be equipped with EQ and other niceties. For instance the A500SE (an average sized monitor) are rated 25-40,000Hz +/- 1.5 dB.
Not to derail this thread. Where did you purchase the A500SE, as I can't seem to find a US dealer.
« Reply #21 on: 15 Jul 2023, 03:24 pm »
Only available online, although they have a U.S. based warehouse.  Note that the A500SE was a limited production product that is sold out now.  The replacement is the A10, but lacks the rear Purifi mid/woofer.  Go to Buchardtaudio.com.
mav52
« Reply #22 on: 15 Jul 2023, 09:58 pm »
Thank you.
« Reply #23 on: 16 Jul 2023, 02:03 am »
When built from a kit, my LS9's are in the $5000 range.  There are few better.
I think you win.  But those aren’t available anymore are they?
« Reply #24 on: 16 Jul 2023, 03:05 am »
Also avoid SS amps with horn drivers or speakers.
Why does Klipsch recommend Onkyo and Pioneer/Pioneer Elite?
https://www.klipsch.com/av-receivers
ONKYO RECEIVERS
TX-RZ50 AV Receiver
TX-NR7100 AV Receiver
TX-NR6100 AV Receiver
TX-NR6050 AV Receiver
TX-NR5100 AV Receiver
TX-NR696 AV Receiver
TX-SR494 AV Receiver
TX-SR393 AV Receiver
PIONEER ELITE RECEIVERS
Elite VSX-LX805 AV Receiver
Elite VSX-LX505 AV Receiver
Elite VSX-LX305 AV Receiver
Elite VSX-LX105 AV Receiver
PIONEER RECEIVERS
VSX-935 AV Receiver
VSX-834 AV Receiver
VSX-534 AV Receiver
VinceT
« Reply #25 on: 16 Jul 2023, 03:12 am »
Only in the used market
There was a pair for sale here amd think they are still available, seller from Michigan. I almost bought them before I found my pair. Can be had for under the 5k too.
« Reply #26 on: 16 Jul 2023, 04:26 am »
They dont even rec a Class A SS amp, by its site I can only believe they hate hi-fi audio and Stereo small tube amps and are steering his products where the market is Home Theater, Lifestyle, powered speakers, outdoor speakers, computer speakers, Bluetooth, tabletop and in wall speakers, they have all the stuff.
But you can use a movie receiver no prob, when you get hearing fatigue you turn off the system and go for a coffee.
« Reply #27 on: 16 Jul 2023, 07:35 am »
What about using a better integrated amplifier?
« Reply #28 on: 16 Jul 2023, 08:20 am »
It can works, always liked low power FET amps in the English style as Rega, usually they have a musical sound.
« Reply #29 on: 16 Jul 2023, 12:56 pm »
I've owned two pair of tiny Temple Audio 70 watt mono-blocks from England and loved them.
« Reply #30 on: 16 Jul 2023, 09:32 pm »
dflee
« Reply #31 on: 17 Jul 2023, 03:01 am »
I'm presently listening to the Fyne 501SP and am pretty impressed.
I wasn't sure they would have the umph for my room and the Magnesium
tweeter was a God I hope they settle down (which they did). The speaker
is pretty danged good in both departments. I'm not able to use bookshelf so the tower was a must.
Don
