Power Amp connections
0 Members and 1 Guest are viewing this topic. Read 733 times.
Boroman1
« on: 28 May 2023, 11:25 am »
Hi, I'm sure that this has been asked before but if I connect my Bryston preamp to my Bryston power amp with XLR cables can I also connect my phono stage with volume control direct to the power amp with phono plugs?
NekoAudio
    • Neko Audio LLC
Re: Power Amp connections
« Reply #1 on: 28 May 2023, 06:06 pm »
I do something similar with a 4B3 amplifier here, which lets me use the input toggle switch to select XLR or RCA on the amp. You probably want to only have one source playing at a time though, even with this configuration.
Boroman1
« Reply #2 on: 28 May 2023, 06:47 pm »
Thanks for that - I'd have thought that it's got to be better to pass the phono signal direct to the power amp bypassing the preamp.
