A couple more questions about SonicT amp power supplies
0 Members and 1 Guest are viewing this topic. Read 1806 times.
Jonathan
1. Using a wall wart, is there a preferred mA rating, or is there any reason to expect that a 500 mA 12vdc would be less (or more) effective or sound different from a 1000 mA?
2) Is there any way to get power to two SonicT amps using just one wallwart or SLA battery? I know that with guitar effects pedals, you can use one wall wart and 'daisy chain' several in a row.
Jon
Jon L
« Reply #1 on: 22 Apr 2005, 05:33 pm »
People have reported good results with 1.5-2Amp power supplies.  I use 7Amp linear PS b/c it was cheap on ebay, and the sound improvement was HUGE compared to 500mA wallwart I had on hand.  It'll sound like a different amp.  Search the ebay for Astron linear regulated power supplies.  Anything with 1.5 Amp or above will do fine.
jakev2003
« Reply #2 on: 22 Apr 2005, 09:53 pm »
How do you wire the PS with the + and - connectors to the SI? Pictures demostrating this would be great.
albee
« Reply #3 on: 23 Apr 2005, 06:50 am »
To power 2 SI's you just hop on down to RatShack and buy two mini plug adapters with cables.  About $10.  They have spades for +/- and you can stack the spades in the power supply's terminals or SLA's alligator clips.  I tried a 5amp cigarette adapter cable and didn't care for the sound.  The gauge of the cable seems to have a softening effect.
jswallac
« Reply #4 on: 23 Apr 2005, 03:39 pm »
Jon L - Which model Anstrom power supply do you use?  Thanks.
Jon L
« Reply #5 on: 23 Apr 2005, 05:55 pm »
Quote from: jswallac
I got the Astron RS-7A regulated linear PS off ebay.  It's 7Amp, SI totally doesn't need, but it was on auction and was cheap  :mrgreen:  Anything 1.5A or above should be more than enough.
I made my own cable using some teflon silver-plated wire and the little round plug I had lying around.  It should be center-positive in U.S. (red thumscrew to center pin).
Jonathan
« Reply #6 on: 25 Apr 2005, 06:38 pm »
So, with this setup, aren't you minimizing the amount of power going to each amp or at least reducing the length of charge time on your SLA?
Thanks.
