isolation devices
0 Members and 1 Guest are viewing this topic. Read 2693 times.
jrdcesq
isolation devices
« on: 22 Apr 2005, 12:55 am »
Hi:
I have a SOTA Nova with a grahm 1.5t and a van den hil mc1 super special. It is a sprung design. Right now I have them on the top shelf of a target stand with the upturned spikes.
I need better isolation. I have been considering the bright star airmas, the  ginko cloud 10 and a nuance shelf. Any opinions would be appreciated. Also, can I use either the ginko or bright star as a shelf or should I put them on the existing shelf.
thanks
John
PeteG
isolation devices
« Reply #1 on: 22 Apr 2005, 02:29 pm »
I’ve been very impressed with the Ginko cloud 11, I use it with a Target wall mount a very good match. Low bass has no effect now on my TT. You can check it out in my gallery.
Pete
woodsyi
isolation devices
« Reply #2 on: 22 Apr 2005, 02:35 pm »
John,
If you are in The Village, you can get one of these.  http://www.audiocircle.com/index.php?topic=18235
jrdcesq
isolation devices
« Reply #3 on: 22 Apr 2005, 06:19 pm »
woodsyi:
Thanks for the lead. I bought one. I think I am going to combine it with an airmas.
John
PhilNYC
isolation devices
« Reply #4 on: 22 Apr 2005, 06:46 pm »
John...what's the dimensions of your table?  I've got a couple of Neuance shelves if you want to try one out...
mcrespo71
isolation devices
« Reply #5 on: 22 Apr 2005, 07:29 pm »
Phil,
How do you like the Neuance shelves?
Michael
jrdcesq
neaunce shelves
« Reply #6 on: 22 Apr 2005, 07:45 pm »
Phil:
How do you like them? I am thinking about using them under the arcam and my amp. The amp is around 50 pounds. How much do you want for them?
thanks
john
PhilNYC
isolation devices
« Reply #7 on: 22 Apr 2005, 09:00 pm »
Michael...I have two Neuance shelves, and I like them very much.  Surprisingly, I found that the one under my amp (Blue Circle BC202 hybrid amp, 70lbs) is more effective than the one under my transport (EA Sony S7700).  I suspect this is because I have the amp on the floor, whereas the transport sits on a TAOC rack...the TAOC has some pretty serious shelves built in (multi-layed MDF with an iron-powder core), so the Neuance there is kind of redundant.
John...not sure if I'm selling them (if I do, it will only be the one I use for my transport, per my comments above).  If I do, it won't be much different than what I paid for it since it is fairly new...your benefit will be that you won't have to wait the 6-7 weeks it takes for Neuance to build it.  But I'm happy to loan it to you if you want to try it first.  Do you happen to know the dimensions/footprint of the Arcam?
jrdcesq
isolation devices
« Reply #8 on: 22 Apr 2005, 11:39 pm »
Phil:
the arcam is 16.75" (430mm) W by 3.33" (85mm) H by 11.33" (290mm), according to stereophile. I don't know what the distances between the feet are. It weighs 18.5 lbs.
thanks
john
PhilNYC
isolation devices
« Reply #9 on: 23 Apr 2005, 01:29 pm »
John...my smaller one should fit the Arcam ok.  I'll have it at HE2005 if you want to pick it up on Sunday...
jrdcesq
neuance
« Reply #10 on: 23 Apr 2005, 05:16 pm »
Phil:
Cool.
John
