NX-Otica - Burn in tips (Bass in particular)
0 Members and 1 Guest are viewing this topic. Read 2181 times.
« on: 9 Feb 2023, 07:52 pm »
So I'm burning in the new crossovers for my NX-Oticas, using various types of music during the day, and then pink noise at night.
One thing I noticed is that the bass on the NX-Oticas main towers always sounded a bit over damped ever since I got them.
From a burn in perspective, you want some tracks that will move the woofers around to get them fully compliant.  I usually use some electronica or hip hop with high levels of bass.  The problem with the NX-Oticas is that even after running these tracks for hours and hours and hours, the bass still sounded off.
Checking the woofers during the bass heavy tracks revealed that even with crazy bass track, they hardly moved.  Wow.  Impressive.  It reminded me of something Danny said about the bass woofers "with 4 woofers per side, you distribute the bass load among them and as a result they hardly even move, not even during big bass passages".
So, I looked around a bit, tried a lot of different things and finally found a track that actually got the woofers to move sufficiently.  Here it is:
The track that you want is this one:
Just put it on repeat for a several hours each day and you can really get the woofers going.  BE CAREFUL WHEN YOU SET THE VOLUME TO MAKE SURE YOU DON'T HIT DRIVER EXCURSION LIMITS.  Best approach is to start at low volume, run the track, make sure there's no problem, turn it up a bit more, run the track, make sure there's not problem, turn it up a bit more, etc...  If you get to the driver's limits, you will hear it.
After doing this myself for the past week or so, I can say that the bass is quite a bit better, no longer 'constipated' sounding.
« Last Edit: 11 Feb 2023, 06:51 pm by Tyson »
350Industrial
Re: NX-Otica - Burn in tips (Bass in particular)
« Reply #1 on: 10 Feb 2023, 01:54 pm »
Cool.  My Oticas are only 6 weeks old with 300 hours on them, but I still have the same impressions regarding the bass that you do.  I'll try this out...
mkrawcz
« Reply #2 on: 10 Feb 2023, 07:07 pm »
It did take a really long time for mine to open up. I didn’t really think about the lack of excursion.
mlundy57
« Reply #3 on: 11 Feb 2023, 01:17 am »
Good album. Thanks  :thumb:
« Reply #4 on: 11 Feb 2023, 04:27 pm »
Yeah, I think any one that has the NX-Otica should try out this burn in track, even if you've owned them for a long time.
SoCalWJS
« Reply #5 on: 11 Feb 2023, 06:11 pm »
Took a bit to find it on Apple Music, but finally did.
Thump Thump Music for car stereo competitions near as I can tell. Instantly caused the problem issues in my room to announce themselves. (Hollow wall section in “Nook” construction)
Yikes!
« Reply #6 on: 11 Feb 2023, 06:26 pm »
Yikes!
The track to put on repeat is this one:
nlitworld
« Reply #7 on: 11 Feb 2023, 09:53 pm »
I just listened to a bass heavy track, then played 2 or 3 tone sweep tracks, then played the same song again and I swear it sounds better. Perhaps every once in a while you just need to let those woofers stretch their legs a little? ¯\_(ツ)_/¯  Either way, fun experiment. And yes, that 40-0 sweep makes my room rattle like a rusted out Ford Bronco.
SoCalWJS
« Reply #8 on: 12 Feb 2023, 04:16 am »
Yup.
I can absolutely understand  frequency wave length with these things, and with this sweep, I realize how much I need to spend some $$$ tightening stuff down.
 :o
Craig Young
« Reply #9 on: 12 Feb 2023, 05:24 pm »
@Tyson Thanks for this post as my kit should be arriving soon. I have been making a cd and the bass sounds so much better streaming from Spotify than my cd. I am listening thru my computer headphones and it doesn't make any difference of the file format that I choose for my cd, but I am grateful for the knowledge of how to get more out of my gear in a shorter burn in period.
tom739
« Reply #10 on: 12 Feb 2023, 10:00 pm »
I would be careful running those tracks on repeat for hours. Depending on volume, voice coils could over heat.
dayneger
« Reply #11 on: 16 Feb 2023, 02:59 am »
Interesting. Makes me wonder what would happen if only 2 of them were used per side.
Where do the woofers cross over to the NX drivers?
