Source for "Very High Quality" .002 Caps for making High Pass Filter?
0 Members and 1 Guest are viewing this topic. Read 1128 times.
jmimac351
I am working up making high pass filters for 2 way speakers, for using with subs.  My Ayre VX-5 Twenty amp has an input impedance of 2M Ohm - Balanced.  Yes, 2 Meeeeelion.  I want balanced connections, which means 1M Ohm per leg.  If high pass crossing ~80hz, that means a cap of .002uF.  I am a novice with this stuff.  Any recommendations on a source for very high quality caps in that spec?  Places like VH Audio don't appear to carry stuff like that.
Thanks for any help / advice.
« Last Edit: 5 Jan 2023, 02:59 am by jmimac351 »
Jaytor
HAL
That is also a 2000pF value.
Since this is for line input, you can also look at polystyrene metal foil caps for RF work.  Most start at 63VDC when I use them.  They also come in 1% and 2% tolerance for matching.
Here is an example and with that many a tightly matched pair is no problem.
https://www.ebay.com/itm/164867834629?hash=item2662e38305:g:bNIAAOSwWPtgn85b&amdata=enc%3AAQAHAAAAoMVbQglr0gVUQEIOiL3YTCqyFZk1VnJwgV0Hl59UYgVqeDuKYgZx%2FhDnPwSHOXfeg2eqxePjB79rYvg0E4K1QQiyorzFc3ObA4uY1gzHZnUHTQspOcQT%2B0MITnYPVwfHHaNiH7qlSyowaxXvhZVu155BCjPHa9VlhpIYDMR0Yvgs1TPZ62XOWTpQOukJ4RGUg5WqdivoI4AayCCJvSOMraQ%3D%7Ctkp%3ABk9SR-L97_ivYQ
LarryD56
I don't know if these are high enough voltage for you, but there are 8- 2200pf Nissei copper/polystyrene 100V caps on the Bay for $30. Those should sound good, but I'm not sure the voltage is hefty enough for your application.
L.D.
jmimac351
Thank you. I'll check this out.  Anyone else who wants to chime in, please do.
LarryD56
There's also the 2200pf 500V Charcroft silver mica caps at PartsConnexion. Those are very high quality and the tolerance is 1% with a higher voltage rating.
L.D.
rollo
  • Rollo Audio Consulting -
  Duelund for crossovers.
charles
charles
Does Duelund make caps in that low a value?
rollo
   I would find out.
charles
