Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
Troubleshooting PS...
0 Members and 1 Guest are viewing this topic. Read 1291 times.
sfox50
13 Apr 2005, 10:44 pm »
Jim- I just hooked a shielded output to my power supply to try & eliminate hum, but now I've lost the -15v output. The + 15 is ok, & the LED is lit,of course. What should I check- the diodes?I assume the transformer is ok...Thanks..
hagtech
Facilitator
14 Apr 2005, 01:45 am »
Most likely the -15V supply is shorted to ground. Many people seem to do this. Disconnect your output cable and it will probably return.
jh
sfox50
Reply #2 on:
14 Apr 2005, 10:26 pm »
Jim- You nailed it!- the + and - seem ok now. ( Glad I'm not the only one!
) I want to separate the PS from the bugle to get away from other components, the hum was pretty loud.What would be good for a power lead(other than the two conductor + ground coax that caused this problem)?
hagtech
Facilitator
Reply #3 on:
15 Apr 2005, 06:11 am »
I like to deliver power on twisted pairs. Not a tight twist, loose, maybe 1.5 turns per inch. Just like CAT5.
jh
Other Stuff
Hagerman Technology
hagtech
