Other Stuff
Archived Manufacturer Circles
Hagerman Technology
hagtech
Cornet2 cap tweak. Help
0 Members and 1 Guest are viewing this topic. Read 1337 times.
rotcoddam
8 Apr 2005, 03:46 am »
Would I be going backward if I paralleled 2 .47uf caps at c208 instead of the 1uf. I have some russian paper in oil caps to try out, but I don't want to waste time with this if it's not a good idea. Any opinions? There would be a .47 p.i.o. and a .47 film. Thanks.
jeffreybehr
Volunteer
8 Apr 2005, 03:51 pm »
Unless C208 is a very-tight-tolerance cap, say, in a critical filter circuit, two 0.47s are well within the standard + or - 10% tolerance.
Let 'er rip!
Why not use 2 of the Russian PIOs?
hagtech
Facilitator
ยป
Reply #2 on:
8 Apr 2005, 06:16 pm »
I'd go with just one of them. As a coupling cap, 0.47uF is usually large enough. Parallel caps of similar size or type can cause smearing of the sound.
jh
Other Stuff
Hagerman Technology
hagtech
