0 Members and 1 Guest are viewing this topic. Read 4140 times.
I agree with the general assertion that other VPI models short of the Avenger series would be a step up from my Rega. As a bit of background, I just upgraded my digital front end to a "practical end game DAC"; HUGE improvements. I am looking to do similar while I have the funds for the analog end. So TT/Tonearm/Cartridge and Phono Pre all at once. I have a very, very generous budget that would not usually be in the cards; so want to get a setup to grow old with (I am pretty old already) Just don't want to end up with "could have, should have" regrets as later I won't be able to afford this.Also looking at Dr. Feickert Blackbird with a Kuzma tonearm, a similar price range.So looking to find the sweet spot in the offerings of several manufacturers, then start comparing relative performance.
I was in a similar situation, really wanted an end game TT, looked at some of those choices. I bought an Acoustic Signature Typhoon Neo TT, Acoustical Systems Aquilar tone arm, and DS Audio 003 optical cartridge/equalizer. It accepts up to 3 arms if you want, very simple to set up. I've had 3 VPI's over the years, though much less costly than this one, none of them moved me the way the Typhoon does and they were finicky. Unfortunately the Typhoon made the DAC I thought to be quite good, sound almost mediocre.
Not a fan of VPI/Music Hall
I currently own a Rega P3. What in the VPI line would be a significant upgrade? Budget is not a major factor. I like the Rega, but want the flexibility that VPI turntables appear to bring (multiple tone arms, upgrade path). Please no suggestions at this point for XY or Z brands. Thanks in advance.
