Industry Circles
Bryston Limited
BP 26 and PS
BP 26 and PS
0 Members and 1 Guest are viewing this topic. Read 1464 times.
stereoal
BP 26 and PS
29 May 2022, 05:05 pm »
I'm setting up my Bryston system and have forgotten whether the power supply is supposed to on a shelf above or below the shelf where the BP26 is located. I remember James saying there is sonic difference when the preamp and power supply are on different shelves.
GSDaudio
Re: BP 26 and PS
29 May 2022, 05:59 pm »
I remember James saying there was about 4dB noise floor improvement with the PS on top. So its been that way ever since.
Highendfool
It is what you think.
Re: BP 26 and PS
Reply #2 on:
30 May 2022, 03:38 pm »
I keep mine two shelves apart. NO interaction that way.
Only stands to reason that the power supply is in a separate, shielded enclosure so it doesn’t interact with the audio circuits!
Why put the cases in close proximity if you can avoid it?
tipatina
Re: BP 26 and PS
Reply #3 on:
30 May 2022, 10:48 pm »
I did separate shelves. Photo
in my gallery
GeAllan70
Re: BP 26 and PS
Reply #4 on:
31 May 2022, 03:03 pm »
Sexy!!
Industry Circles
Bryston Limited
BP 26 and PS
