Tact room correction or traps`?
0 Members and 1 Guest are viewing this topic. Read 1937 times.
Florian
« on: 6 Apr 2005, 08:53 pm »
Well as the title indicates. I would like to know what i should do, i can buy a Tact 20. with the AD converter for around 1600$...or i can spend it on traps.
Ideas?
Flo
Florian
« Reply #1 on: 6 Apr 2005, 09:07 pm »
Never mind, i bought a Tact 2.0 with all aaccesorys incl. the DA and AD converters
Red Dragon Audio
    • http://www.reddragonaudio.com
« Reply #2 on: 6 Apr 2005, 09:13 pm »
Damn that was fast!
I would have said go with some Real Traps or DIY versions then after having treated the room properly, use the TACT unit to tidy up what problems still persist. :wink:
Bingenito
« Reply #3 on: 6 Apr 2005, 09:16 pm »
Ditto.
I would have recommended measuring the room to see where you have issues and then see if they can be corrected with room treatments.
I guess you will be using your AA as a transport and just run digital out to the TACT? It may work out because the DAC in the Tact might be better then the AA
Florian
« Reply #4 on: 6 Apr 2005, 09:18 pm »
Lol, well i am a quicky lover  :lol:  :lol:
Anyways, it was a no brainer. The retail is well over 4k with all the stuff. I got it from the factory with a 2 year warranty with the preamp and the DA and AD converter for 1600$ incl. shipping
Florian
« Reply #5 on: 6 Apr 2005, 09:20 pm »
Quote from: Bingenito
Ditto.
Ill run the digital out from the AA to the Tact and then use it as a premap into the Krell
Bingenito
« Reply #6 on: 6 Apr 2005, 09:24 pm »
Better add TACT 2.0 to your signature  :lol:
Florian
« Reply #7 on: 6 Apr 2005, 09:26 pm »
Muhaahha.....i will soon :-)
the good thing is that this eliminates my 220V to 110V converter and eats less power. Which is good, then the converters and the Krell are killing me ;-)
