Speakon Connector wiriing
0 Members and 1 Guest are viewing this topic. Read 893 times.
jimbones
« on: 13 May 2022, 04:20 pm »
can someone provide the pin out config for the speakon connector for the H frame double 12s. I have to do some repair work and wanted to make sure I dont mix up the sense coil from the drive voice coil. Thanks
jparkhur
Re: Speakon Connector wiriing
« Reply #1 on: 13 May 2022, 04:40 pm »
if you are using the four input connector, depending on how you connected the, look at the numbers under the grommet.  I have 1 and 2 as positive and negative and 3  and 4 as servo in and out.  Make sure the female and male ends are the same per number.   If you are looking for the wiring diagram for the servo or subs, the subs are in parallel  and servo in series. (someone please edit me if I am off).
jparkhur
« Reply #2 on: 13 May 2022, 04:40 pm »
as long as they match, dont matter what hole you use.
JP
jimbones
« Reply #4 on: 13 May 2022, 05:43 pm »
Thanks all  :thumb:
