Alternative amps to use with Subs
0 Members and 1 Guest are viewing this topic. Read 1566 times.
jimbones
« on: 8 May 2022, 07:53 pm »
I built up a pair of H Frame Servos. Has anyone tried an amp other than the Rythmik A370 on their Subs? I was considering trying a non servo amp just for the hell of it. Please share your experiences Thanks.
corndog71
  • Some people call me Rob.
Re: Alternative amps to use with Subs
« Reply #1 on: 9 May 2022, 12:02 am »
That’s like putting a 4 cylinder engine in a Mustang.  Definitely a downgrade.
jparkhur
« Reply #2 on: 9 May 2022, 01:15 pm »
You can not use servo subs well at all without a servo  amp.   They sound terrible and bottom out constantly.  Now if you like to tinker, then you could use other OB subs with the same H frame and run them off what ever amp you want.   I did this in this   https://www.audiocircle.com/index.php?topic=139868.msg1893175#msg1893175.   I used the Acoustic Elegance 12s, in place of the servo subs for my Super v and other items.  I have them now in a lower H Frame.
Servo Needs Rhymik Amp.. period
tom739
« Reply #3 on: 9 May 2022, 09:36 pm »
I heard Acoustic Elegance makes a quality woofer. How well did the open baffle subs work with AE woofers?
jparkhur
« Reply #4 on: 9 May 2022, 09:44 pm »
Can only be one small notch below the speed of servo. Had both. Liked both. Still have the AE
« Reply #5 on: 9 May 2022, 10:48 pm »
I've heard the AE-15 fifteen inch midrange driver paired with the Beyma AMT tweeter and it was one of the top 5 systems I've ever heard in my life.  And that was with no subs.  I'm willing to bet pairing it with a couple of servo OB subs it might have taken the top spot.  AE makes incredibly good drivers.
jparkhur
« Reply #6 on: 9 May 2022, 10:52 pm »
And he is local ish. I drive bye once in awhile.
jimbones
« Reply #7 on: 14 May 2022, 09:33 pm »
is there a better servo amp other than the A370?
Also how did you like the AE woofers. My buddy uses them with audio control amps and they are incredible
jparkhur
« Reply #8 on: 14 May 2022, 09:36 pm »
No that servo tech only works w the Rhymik amps.  They are truly great. AE are fast and great in the H frame.
Hobbsmeerkat
« Reply #9 on: 14 May 2022, 10:02 pm »
Currently there aren't any better amps offered by rythmik, just different kinds.
The most powerful ones they have are the HX 800, which is a 2-channel Hypex servo amplifier. It can run up to 6 woofers in total.(3 per channel)
However Rythmik has been plauged by the ongoing chip shortage making it really difficult for them to get any amplifiers right now.
jimbones
« Reply #10 on: 14 May 2022, 10:20 pm »
ok thanks.
jimbones
« Reply #11 on: 14 May 2022, 10:21 pm »
but that means the AE are not servo and you use another amop? My buddy's Audio Control work really nice with the AE in the H Frame
jparkhur
« Reply #12 on: 14 May 2022, 10:27 pm »
Yes. Regular plate amp. Works perfect
