Finding 24V, 2A lead-acid battery charger for Dodd preamp
0 Members and 1 Guest are viewing this topic. Read 1559 times.
ctviggen
I have a similar Dodd Preamp:
https://www.audiocircle.com/index.php?topic=166628.msg1769700#msg1769700
I was going to give this to a family member to use, as I cannot integrate it into my system.  However, I realize I do not have the charger.
The charges is a 24V, 2A lead-acid battery charger. Anyone know how I can find one of these?  In particular, what model/type do I need?  And where can I get a tip that mates with what the Dodd has?
Thank you.
ctviggen
Re: Finding 24V, 2A lead-acid battery charger for Dodd preamp
« Reply #1 on: 16 Apr 2022, 03:37 pm »
After searching quite a while, I found this thread on it:
https://www.audiocircle.com/index.php?topic=151399.0
I'm going to buy the charger, just need to figure out a tip to buy too.  And then test the batteries.
S Clark
« Reply #2 on: 16 Apr 2022, 04:02 pm »
Glad you found a solution.  There are some at Amazon that could be made to work for around $50, but if you can find the Soneil unit, it was the OEM for Gary.  I actually have a spare, but would part with it reluctantly.
