HDMI cable, where to buy?
0 Members and 1 Guest are viewing this topic. Read 1676 times.
jasonc
« on: 4 Apr 2005, 09:28 pm »
Looking to purchase a reliable HDMI cable for under 50.00.. looking for suggestions on where to buy.
Jason
Charles Calkins
« Reply #1 on: 4 Apr 2005, 09:33 pm »
jason:
  Try bluejeanscable.com.
                         Cheers
                         Charlie
jasonc
« Reply #2 on: 4 Apr 2005, 09:39 pm »
Charlie,
Thank you, I had them in mind.
F-100
« Reply #3 on: 4 Apr 2005, 09:44 pm »
I have no experience with the cables from this company but their prices are pretty cheap.
http://www.cablewholesale.com/catalog/hdmianddvicable.htm
Wayne1
« Reply #4 on: 4 Apr 2005, 09:45 pm »
For an inexpensive, very good quality HDMI cable, it might be worth it to try these folks:
http://www.pacificcable.com/HDMI_Cables.html
I use their DVI cable and have had very good results.
jasonc
« Reply #5 on: 4 Apr 2005, 09:56 pm »
Thanks for the recomendations.  With these prices I could sample one from each company :D .
tvyankee
« Reply #6 on: 4 Apr 2005, 10:03 pm »
hey
try these guys they rock.
http://www.ramelectronics.net/html/DVI-hdmi_cables.html
good luck.
klh
« Reply #7 on: 5 Apr 2005, 12:10 am »
TV Yankee,
What do you know about their cables in general (or specifics)? The have good prices, but are the wires decent quality? I looked at the speaker cables, power cables, etc, and they look nice (fairly simple... they could probably be done at home).
tvyankee
« Reply #8 on: 5 Apr 2005, 12:16 am »
hey
their stuff is very good quality and they always have stock.
also if you have any tech ?'s they have a tech department.
i have used them a bunch of times in the past and they always have done the right thing.
give them a shot you won't be let down.
klh
« Reply #9 on: 5 Apr 2005, 05:01 pm »
Thanks. I'll keep them in mind :)
F-100
Cheapest HDMI cable
« Reply #10 on: 14 Apr 2005, 10:33 pm »
Steren HDMI Cable for $15.99.  See link below.
http://www.buy.com/retail/product.asp?sku=90142650&dcaid=1688
ekovalsky
« Reply #11 on: 14 Apr 2005, 11:03 pm »
Quote from: tvyankee
hey
good luck.
I just got their "high end HDMI" cable in 6ft length for around $40 shipped.  Service was very fast, cable is nicely made and works great.  I don't see much difference in pic quality compared to the component it replaced (between SA 8300HD DVR and Sony Qualia 006), but the audio is definitely improved.
