0 Members and 1 Guest are viewing this topic. Read 14597 times.
Rick,Any progress reports on a future DEQX array ?
I know the question is directed to Rick but I thought that I would share that I heard a DEQX array. It was the same dipole array (yes I have read that DEQX does not do as well with Dipoles) that Rick heard a few months back.The owner has the speakers voiced a little more laid back then the Incredarray but is using Seas Excel mid-bass drivers.Since Rick was over there the owner has been tweaking the system. I have to tell you that the soundstage was down right spooky. He played a few tracks I have n ...
Thanks for the kind words about the system, you heard it in the 45" version with 8 of the excels per side, last night (at about 2 AM), the new 90" arrays were completed in "test" form, these use 15 excels per side and 2 stacked 45" newforms per side. The linkwitz dipole subs got moved out to side walls which changed the room response, I'll have to run a new correction curve for the system, the music went on as soon as everything was connected. The sound improved notably in some key areas, you'll have to come back out to listen. Re the dipole bass, it takes a bit of getting used to and one has to have the equipment to do the neccessary EQ, but it provides very fast detailed dynamic bass and once one is used to it, most all monopole bass just sounds boomy and too involved with the listening room.
I have used my DEQX with my Needles line array (16 Tang Band W3-871S and a single Aurum Cantus G3 per side). While I can not A-B versus the passive crossover, I can tell you that the DEQX calibration process creates an exceptional crossover and great sound. I started with roughly the same crossover points as for the passive network but clearly with higher slopes. The results are scary good and very natural in my opinion. I'm new to the DEQX (received it a month ago) but I found it relatively easy t ...
TKPI am with you on holding off. Not so much for the cost but in a few yrs the DEQX you buy for $3k will be improved. Maybe easier to use, better DAC, etc
If you can afford it now why wait? Although this is a constantly changing/evolving technology, the impact it has on a system is well beyond the cost a simple component upgrade.
The vast majority of the truly great systems I have heard at residences, dealers, and shows, have been dipoles. Usually they were mated with a dynamic subwoofer system.I still wish I had kept my Apogee Divas and Muse18 subs
I understand the hesitation on using the Tact since it does a conversion, but to my ears, the correction is so much more positive than the negative of the conversion that you still come out well ahead in terms of the improvement to the sound.If you have any way of trying the Tact preamp, I heartily recommend you give it a try.In terms of correction in thr analog domain, there is the Rives product.George
