0 Members and 1 Guest are viewing this topic. Read 5283 times.
I've got an Onkyo TX-NR905.One more question... If I connect a DVD player via HDMI to the receiver, do I lose the benefit of using a great DVD player? Or, would I use alternative connections to maintain the quality?
If your "main 2 channel rig" has a DAC, just concurrently run the Optical or Coax Digital out from your DVD player to your 2 channel rig for simple straight 2 channel listening.If it doesn't have a quality DAC, then you are limited to the HDMI through the AVR.
For movies:The DVD player will feed the receiver first.. with HDMI, am I bypassing all the good video processing going on when I hand it off to the receiver? Or would I benefit from hooking up line outs from DVD to receiver? I just have to wonder about people who post that the new Panasonic isn't as good as their Oppo because the way the signal is being handled/managed/translated. The reviews are inconsistent and no one mentions how they hooked it up, what type of cables, etc. I guess I'm looking for an 'ideal'... cheap dvd players give you no choice, it's hdmi and optical only. This DVD has analog line outs. Is that better? Or, do we know if the video signal from the DVD player is getting to the receiver with all the information needed? I'm just a little unclear about this part.
I have an entry level PSB but I hope to get something nicer that blends a bit better with the Piegas while being an easier load... That way I don't have to buy an amp. But if I do, it'll be ok.
