**SOLD**Yamaha RX-A2060 Atmos Receiver
0 Members and 1 Guest are viewing this topic. Read 923 times.
Big Red Machine
« on: 15 Oct 2021, 01:03 pm »
https://usa.yamaha.com/products/audio_visual/av_receivers_amps/rx-a2060_u/index.html
I'll grab some photos this weekend. I have the original box, remote, mic, cabling, manual, wi-fi antenna, packaging, etc.
$700, CONUS shipping
This 9.2-channel AVENTAGE network AV receiver features Dolby Atmos® and DTS:X™ for surround sound realism. With the latest in HDMI® technologies, experience movies in stunning 4K Ultra HD and high dynamic range (HDR). The free MusicCast app makes it easy to access your music library and streaming music services. Add audio in up to 9 additional rooms with MusicCast wireless speakers or other MusicCast devices. Wi-Fi®, Bluetooth® and AirPlay® wireless connectivity, a phono input for vinyl playback and advanced HDMI zone switching provide added system versatility.
The AVENTAGE Advantage: Designed to deliver the highest levels of audio performance through engineering
Aluminum front panel with door, symmetrical amplifier layout, H-shaped cross frame
9.2-channel Dolby Atmos® and DTS:X™ (7.1.2-ch or 5.1.4-ch)
11 speaker terminals with Intelligent Amp Assign for Zone 2
Voice control using your Alexa device like Echo or Echo Dot
HDMI® (8 in / 2 out) with 4K Ultra HD full support, HDR Video including Hybrid Log-Gamma and Dolby Vision™
Advanced HDMI zone switching (Zone 2)
HDCP 2.2, high dynamic range (HDR) and BT.2020 compatibilit
High-performance digital-to-analog conversion (ESS SABRE Premier Audio DAC ES9006A x 2)
Fully loaded with Wi-Fi, Bluetooth, AirPlay and Spotify Connect
Stream Pandora®, Spotify, Napster, SiriusXM Internet Radio, TIDAL, Deezer and thousands of free internet radio stations.
DSD 2.8 MHz / 5.6 MHz, FLAC / WAV / AIFF 192 kHz / 24-bit, Apple® Lossless 96 kHz / 24-bit playback
Phono input to connect to your favorite turntable
Room acoustics optimization using YPAO™ - R.S.C. with 3D, multipoint and angle measurement
Amplifier SectionChannelRated Output Power (1kHz, 2ch driven)Rated Output Power (20Hz-20kHz, 2ch driven)Maximum Effective Output Power (1kHz, 1ch driven) (JEITA)Dynamic Power / Ch (Front L/R, 8/6/4/2 ohms)Surround Sound ProcessingCinema DSPDSP ProgramsDialog Level AdjustmentVirtual Presence SpeakerVirtual Surround Back SpeakerDialogue LiftSILENT Cinema / Virtual Cinema DSPDolby AtmosDolby TrueHDDolby Digital PlusDolby SurroundDTS:XDTS-HD Master AudioAudio FeaturesPure DirectCompressed Music EnhancerHigh-resolution Music EnhancerYPAO Multi-point MeasurementYPAO VolumeAdaptive DRC (Dynamic Range Control)Initial Volume and Maximum Volume SettingA.R.T. WedgeBi-amp CapabilityAudio Delay192kHz / 24-bit DACs for all channelsVideo Features4K Ultra HD Pass-through and UpscalingHDMI 3D Pass-throughHDMI Audio Return ChannelHDMI UpscalingVideo AdjustmentDeep Color / x.v.Color / 24Hz Refresh Rate / Auto Lip-SyncExtensive ConnectionHDMI Input/OutputHDMI CECUSB InputNetwork PortFront AV InputDigital Audio Input / Output: OpticalDigital Audio Input / Output: CoaxialAnalog Audio Input / OutputComposite Video Input / OutputPreoutHeadphone OutputConnectivityWi-FiAirPlayBluetoothPhono InputComponent Video Input/OutputTuner SectionFM / AM TunerUser InterfaceOn-Screen DisplaySCENEApp ControlWeb Browser ControlRemote Control UnitZone ControlZone 2 Audio OutputZone 3 Audio OutputZone 4 Audio OutputPowered ZoneZone Video OutputZone HDMIZone B OutputZone GUIRS-232C Interface+12V Trigger OutputRemote (IR) Input/OutputParty ModeGeneralStandby Power Consumption (IR only)Auto Power StandbyECO ModeDimensions (W x H x D)Weight
RX-A2060
RX-A2060
AV Receiver
Amplifier Section   Channel   9.2
Rated Output Power (1kHz, 2ch driven)   155 W (8 ohms, 0.9% THD)
Rated Output Power (20Hz-20kHz, 2ch driven)   140 W (8 ohms, 0.06% THD)
Maximum Effective Output Power (1kHz, 1ch driven) (JEITA)   220 W (8 ohms, 10% THD)
Dynamic Power / Ch (Front L/R, 8/6/4/2 ohms)   165 / 210 / 285 / 405 W
Surround Sound Processing   Cinema DSP   Yes (3D)
DSP Programs   23
Dialog Level Adjustment   Yes
Virtual Presence Speaker   Yes
Virtual Surround Back Speaker   Yes
Dialogue Lift   Yes (no presence speakers required)
SILENT Cinema / Virtual Cinema DSP   Yes (Virtual CINEMA FRONT)
Dolby Atmos   Yes
Dolby TrueHD   Yes
Dolby Digital Plus   Yes
Dolby Surround   Yes
DTS:X   Yes
DTS-HD Master Audio   Yes
Audio Features   Pure Direct   Yes (with video on mode)
Compressed Music Enhancer   Yes
High-resolution Music Enhancer   Yes
YPAO Multi-point Measurement   Yes with R.S.C. (Reflected Sound Control), 3D and Angle measurement
YPAO Volume   Yes
Adaptive DRC (Dynamic Range Control)   Yes
Initial Volume and Maximum Volume Setting   Yes
A.R.T. Wedge   Yes
Bi-amp Capability   Yes
Audio Delay   Yes (0-500 ms)
192kHz / 24-bit DACs for all channels   Yes (ESS)
Video Features   4K Ultra HD Pass-through and Upscaling   Yes (4K/60p, 4:4:4)
HDMI 3D Pass-through   Yes
HDMI Audio Return Channel   Yes
HDMI Upscaling   Yes (Analog to HDMI / HDMI to HDMI)
Video Adjustment   Yes
Deep Color / x.v.Color / 24Hz Refresh Rate / Auto Lip-Sync   Yes
Extensive Connection   HDMI Input/Output   8 / 2 (7 HDCP 2.2 inputs, HDR10 and BT.2020 compatible)
HDMI CEC   Yes (SCENE, Device Control)
USB Input   USB Memory, Portable Audio Player
Network Port   Yes
Front AV Input   HDMI / USB / Analog Audio / Composite
Digital Audio Input / Output: Optical   3 / 0
Digital Audio Input / Output: Coaxial   3 / 0
Analog Audio Input / Output   9 (front 1) / 0
Composite Video Input / Output   5 (front 1) / 1
Preout   7.2-ch
Headphone Output   1
Connectivity   Wi-Fi   Yes (with Wireless Direct)
AirPlay   Yes
Bluetooth   Yes (SBC / AAC)
Phono Input   Yes
Component Video Input/Output   3 / 1
Tuner Section   FM / AM Tuner   Yes
User Interface   On-Screen Display   Graphical User Interface
SCENE   SCENE PLUS (12 sets)
App Control   Yes (iPhone / iPad / Android phone / tablet)
Web Browser Control   Yes
Remote Control Unit   Yes
Zone Control   Zone 2 Audio Output   Preout / HDMI
Zone 3 Audio Output   Preout
Zone 4 Audio Output   HDMI
Powered Zone   Zone 2 / 3
Zone Video Output   HDMI / Component / Composite
Zone HDMI   Yes (Advanced HDMI Zone Switching)
Zone B Output   HDMI
Zone GUI   Yes
RS-232C Interface   Yes
+12V Trigger Output   2
Remote (IR) Input/Output   1 / 1
Party Mode   Yes
General   Standby Power Consumption (IR only)   ≤0.1W
Auto Power Standby   Yes
ECO Mode   Yes
Dimensions (W x H x D)   17-1/8” x 7-1/2” x 18-5/8” (with antenna up: 17-1/8” x 9-3/4” x 18-5/8”)
Weight   37.5 lbs.
« Last Edit: 22 Dec 2021, 11:51 pm by Big Red Machine »
Big Red Machine
Re: Yamaha RX-A2060 Atmos Receiver
« Reply #1 on: 17 Oct 2021, 09:23 pm »
Big Red Machine
« Reply #2 on: 25 Nov 2021, 05:31 pm »
bump, ready to ship
