BR-20 Display
0 Members and 1 Guest are viewing this topic. Read 1096 times.
ashtarul
BR-20 Display
« on: 17 Jul 2021, 06:38 am »
Hello,
Is there a way to switch off the display altogether or a display sleep timer (display off) function? If not then maybe in the next software update? Thanks.
Ash
  • The Demo is Everything!
    • http://www.bryston.com
Re: BR-20 Display
« Reply #1 on: 17 Jul 2021, 10:28 am »
Hi Ash
I will check with our software guys.
james
Clive197
Re: BR-20 Display
« Reply #2 on: 17 Jul 2021, 10:50 am »
Hello,
Ash
Hi Ash
I think the solution could be already in the main menu -
Menu - Global Settings - Display Brightness - 0-10 - 0 Should turn it off
Re: BR-20 Display
« Reply #3 on: 17 Jul 2021, 01:40 pm »
You can reduce the brightness but I do not believe it will turn completely off.
james
ashtarul
Re: BR-20 Display
« Reply #4 on: 17 Jul 2021, 02:39 pm »
That's right 0 doesn't turn display off just dim.
R. Daneel
Re: BR-20 Display
« Reply #5 on: 17 Jul 2021, 03:19 pm »
If it's anything like the BDP, the display is powered by the same (separate) power supply that powers the device while in stand-by mode. I believe Chris told me this a few years ago so it is likely possible with the BR-20 too, if the software can be upgraded to accomodate such a feature.
FWIW.
Cheers - Antun
ashtarul
Re: BR-20 Display
« Reply #6 on: 17 Jul 2021, 08:48 pm »
BTW the BR-20 sounds absolutely superb. I doubt that having the ability to switch off the display will have any effect on the sound quality, I just prefer it off if possible. My BR-20 replaces a loaned (by the distributor) BDA-3.14 which I had for approximately 5 months and it  demolishes it in term of details. I'm not sure how this is possible because the DAC is supposed to be identical. Congrats on a wonderful product.
« Last Edit: 20 May 2022, 07:46 pm by ashtarul »
Clive197
Re: BR-20 Display
« Reply #7 on: 17 Jul 2021, 09:29 pm »
It was just a suggestion but I certainly agree about sound quality and if the DAC is the same than let’s put it down to the Pre Amp being so good.
Re: BR-20 Display
« Reply #8 on: 18 Jul 2021, 11:29 am »
Hi Folks,
Yes this is the first preamplifier we have designed with a fully balanced circuit from input to output. It is a much more expensive way to design but it does seem to provide dividends.
Also having the circuit paths of the Streamer/DAC and Discrete Preamplifier sections all integrated and designed to compliment each other seems to provide excellent performance.
best
james
Re: BR-20 Display
« Reply #9 on: 18 Jul 2021, 11:29 am »
Ash - what speakers are they?
james
ashtarul
Re: BR-20 Display
« Reply #10 on: 18 Jul 2021, 06:31 pm »
They are Yamaha NS-5000 James. I also have a pair of the Model T's in the bedroom driven by the BP26 and 14B SST. Both amazing speakers.
