Another new guy orders the Mini
0 Members and 1 Guest are viewing this topic. Read 1401 times.
EdwardT
« on: 15 Jul 2021, 07:49 pm »
The flat pack arrived last night via the brown truck. I’m still in the throes of X-SLS construction but I think I may squeeze in a dry fit tomorrow between finish applications on the towers, and I might even glue the flat pack up. When the electronics get here it'll be full on ahead with the build and an attempt to veneer with this lovely laurel burl:
It’s humid here and the tung oil finish is taking forever to dry:
« Last Edit: 15 Jul 2021, 10:27 pm by EdwardT »
EdwardT
Re: Another new guy orders the Mini
« Reply #1 on: 16 Jul 2021, 05:41 pm »
After a quick dry fir it’s a very easy glue up. Thumbs up to Danny and crew. :thumb:
EdwardT
« Reply #2 on: 17 Jul 2021, 10:29 pm »
Alrighty, one done and one in the clamps.
EdwardT
« Reply #3 on: 3 Nov 2021, 03:30 pm »
mlundy57
« Reply #4 on: 3 Nov 2021, 05:56 pm »
Looking good  :thumb: I like burls also
subsonic1050
« Reply #5 on: 3 Nov 2021, 05:57 pm »
Those look awesome! I really love the veneer.
Danny Richie
« Reply #6 on: 10 Nov 2021, 06:18 pm »
Wow!
oskar
« Reply #7 on: 11 Nov 2021, 04:02 pm »
Nice work!
What is the radius of the round over on the front baffle?
Did you use paper backed veneer?
EdwardT
« Reply #8 on: 11 Nov 2021, 11:59 pm »
That's 1/2” roundover. No paper backing, the burl came as seven leaves cut in sequence and I used Heat Lock glue and an iron. I also used softener on the veneer for the curve. The veneer expanded a lot with the heat and I wished I’d softened the edges, too, but I’m just going to say the burl cracks give it character and save the lesson for next time.
