Bryston 7B SST & 7b SST2
0 Members and 1 Guest are viewing this topic. Read 1035 times.
Nicknapster
« on: 4 Jul 2021, 06:43 pm »
I have 5 Bryston amps. 2 7B SST2 2 7B SST and one 7B ST and I have run into a bit of a problem ( I think it can be fixed? ) anyway I run the amps to feed my set of Wilson Sabrina and a Wilson Watch 3 center.  My problem is, if I run 2 7B SST2 for my fronts and one of my 7B SST for my center ( I run my rears wireless for now ) those are a set of YU 4. Due to limited space in my listening room.  One or more of the 7B SST2 amp lights grow dim and if I turn off the amps they don’t want to come back on until I unplug them from the wall. If I turn off the center amp being one of the 7B SST the 7 B SST2s work fine. The 7B sst amps also work fine. If I remove the 7B SST from feeding my center and replace it with the older 7B ST the 3 amps work to fine. I would like to run one of the 7B SST as my center amp because those amps sound better then the 7B ST.
What do you all think?
Re: Bryston 7B SST & 7b SST2
« Reply #1 on: 4 Jul 2021, 07:43 pm »
Hi,
The Starting Block Circle is really for people to introduce themselves.
This question/thread is best posted in the Bryston Circle, so I wll move it there for you now.
brucek
« Reply #2 on: 4 Jul 2021, 08:28 pm »
My problem is, if I run 2 7B SST2 for my fronts and one of my 7B SST for my center.............One or more of the 7B SST2 amp lights grow dim............
I think the amps are starved for power.
I suspect these amps (along with other items) are all plugged into a single 15 amp outlet and it's not suffice for this load. Have an electrician add some circuits.
brucek
Nicknapster
« Reply #3 on: 4 Jul 2021, 09:04 pm »
Yup that’s the problem. Another problem we have is hat are renting the condo we are now living in so I can’t have an electrician add a dedicated circuit for any of my equipment. The good thing is we’re in the process of building our new house and there’s a media room going into the new house and it’s being built by audio professionals so that problem will completely go away come this December.😃
