newbie - hey there
0 Members and 1 Guest are viewing this topic. Read 696 times.
cynadon
newbie - hey there
« on: 16 May 2021, 02:19 pm »
I just joined and this is my first post. Received my nxtreme flat pack Fri 5/15/21. Very nice, excellent packing, everything is great. Looking for pix/videos or instructions.  Im glad my closest neighbor and friend has a cabinet shop in the back yard. If I cant weld it, I try to pass it off to the somebody else. Any problem spraying everything with primer before we start assembly.
thanks and hey there,
jas from NC
Hobbsmeerkat
Re: newbie - hey there
« Reply #1 on: 16 May 2021, 11:12 pm »
Heya & welcome to AC!  :thumb:
As for videos for the assembly process this thread as a few! https://www.audiocircle.com/index.php?topic=173122.0
This thread also has some pictures that may be helpful:
https://www.audiocircle.com/index.php?topic=169590.0
Phil A
« Reply #2 on: 17 May 2021, 02:12 am »
Welcome!
Jaytor
« Reply #3 on: 18 May 2021, 03:18 am »
I think you want to keep the glue surfaces bare. If you make of the areas where the panels will be glued, you should be ok with priming before assembly, but you may have to do some touch up after you've got everything glued.
