Need a very good Amp,,,,
0 Members and 1 Guest are viewing this topic. Read 1582 times.
2bigears
« on: 8 May 2021, 01:27 am »
 :D hello all good AC peeps near and far. I'm looking for an amp to fit right into my system.  I have a VAC pre and D48r ProAc speakers. They are 4 ohm and 90db. I had a few deals but they fell apart. I'm in Canada and shipping isn't a problem if you ask me. Everything good always comes from the states it seems. 10 times the people.  Any ideas is also greatly appreciated.  I listen to old time R&R and the likes. 60's & 70's.  medium size room.  :D
I.Greyhound Fan
Re: Need a very good Amp,,,,
« Reply #1 on: 8 May 2021, 02:51 am »
https://www.usaudiomart.com/details/649735113-pass-labs-xa-605-mono-block-power-amplifiers/
https://www.usaudiomart.com/details/649369868-mcintosh-mc452-power-amp-top-of-the-line/
https://www.usaudiomart.com/details/649733107-parasound-jc-1s-silver-pair/
aln
« Reply #2 on: 8 May 2021, 01:24 pm »
Van Alstine 600 on this for sale board.
JakeJ
« Reply #3 on: 9 May 2021, 04:08 am »
2bigears,
I think the Pass Labs XA-60.5 recommendation is an excellent one.  I own the X(non-A)-350.5 and can testify as to the SQ and sheer power.  Now the XA-60.5 is pure class A to 60 Watts and provides substantial headroom beyond that.  The specs say it leaves class A at a peak output of 122 Watts!  Fully double the rated output.  My X-350.5 leaves class A at 40Watts so when not crankin' the system I do get Class A benefits.  And yes class A amplifer operation is the shit for Solid State.  I also have a pair of Krell KMA-160 monos, a pair of Threshold SA-1 monos (both rated at 160 Watts pure class A), a pair of Monarchy Audio SE-100 delux monos (100 Watts class A, these were real sleepers).
If you want this amp to be the end all be all then I'd hold out for a pair of the .8 amps in your desired power level.
Just my .02
opnly bafld
« Reply #4 on: 10 May 2021, 03:47 pm »
FWIW all Monarchy Audio amplifiers are high bias class A/B.
I believe a pair of SE 100 MK IIs are available for under 2k.  :thumb:
100w 8 ohms, 200w 4 ohms
9"w x 5"h x 12"d - 22lbs each
SE 160 Hybrid and SE 250 Hybrid monoblocks for more power and tube input stage.
Call or email for prices.
2oldcranks
« Reply #5 on: 10 May 2021, 04:32 pm »
Hi 2BE
I would bet any of Tommys DAC cherry amps would sound superb with that pre and drive the 4ohm proacs easily,Lots of folks like/recommend a good class d with tube pre for best of both worlds. Lots of good options out there,best of luck in your hunt :thumb:
Peace
/mp
« Reply #6 on: 10 May 2021, 04:40 pm »
....I'm looking for an amp to fit right into my system.  I have a VAC pre and D48r ProAc speakers. They are 4 ohm and 90db....medium size room.
OP's question is unanswerably vague. Budget? New/used? SS/tube? Twin mono/stereo? Fabergé-esque/plain box. Etc. One person's overkill is another person's not good enough.
As always, YMMV.
opnly bafld
« Reply #7 on: 10 May 2021, 04:45 pm »
As always, YMMV.
Agree, but if you look at his other dozen or so posts you can get a little better understanding of the confusion.  :green:
aln
« Reply #8 on: 13 May 2021, 12:26 pm »
And what are you buying?
JakeJ
« Reply #9 on: 14 May 2021, 04:43 pm »
Yes!  Do tell and pictures please.
musicdre
  • reality is the base
    • art site
« Reply #10 on: 14 May 2021, 05:20 pm »
and not sure why this convo is in trading post and not somewhere more appropriate.  moderator?
« Last Edit: 17 May 2021, 12:04 pm by musicdre »
