Hello
0 Members and 1 Guest are viewing this topic. Read 870 times.
srivenkat
Hello
« on: 26 Apr 2021, 12:58 am »
Hello everyone. New to the site, interested in tube audio gears. I am interested in building tube gears and learning from the fundamentals. Glad to be part of this forum.
Blackmore
Re: Hello
« Reply #1 on: 26 Apr 2021, 01:18 am »
Welcome to AudioCircle
Re: Hello
« Reply #2 on: 26 Apr 2021, 03:09 am »
Welcome to AC  :thumb:
Do you are a experiencied tech in electronics ?
Phil A
Re: Hello
« Reply #3 on: 26 Apr 2021, 12:21 pm »
Welcome!
Re: Hello
« Reply #4 on: 27 Apr 2021, 03:05 am »
Greetings & Welcome to AC srivenkat   :thumb:
srivenkat
Re: Hello
« Reply #5 on: 27 Apr 2021, 02:03 pm »
No, not at all :) I have interest in learning and building my own - going thru some fundamentals & youtube channels :)
Re: Hello
« Reply #6 on: 27 Apr 2021, 04:25 pm »
If you not a experiencied technician in hi voltage and a Copperfield with the soldering iron to weld thick solid wire, I recommend dont mess around tube amps, they are dangerous and work with hi voltage DC, I can testify it why if there was not a person close to me I would have died.
DC tension is not safe as Edison said its a lie, DC tension so low as 30V DC already can kill a man by disturbance of the heart rhythm.
A Solid State amp or DAC is much more safe to work, above 500V DC can happen corona discharge from transformers to a near person, this is a voltage value common to be found in big tubes as 211,845,GM70,GK71 and even in smaller tubes as GU50.
Some safety procedures to work in tube amps are:
Rubber boots, rubber or leather gloves, no rings, no watches, protective goggles, keep a capable person near you etc...
« Last Edit: 27 Apr 2021, 06:46 pm by FullRangeMan »
