0 Members and 1 Guest are viewing this topic. Read 6660 times.
With all the concern over the most miniscule amounts of "smearing and distortion" in their components and cabling, I wonder if anyone knows how much "distortion" is introduced by the listening room?Distortion is "any" addition or subtraction of the original purity of signal.I would guess it is in the neighborhood of at least 30-40%Has anyone heard any numbers?
the distortion that occurs in equipments and speakers are based on electrical, magnetic, mechanical phenomenon while a listening room is basically a space of air where sound travels, to say "room distortion" would be very inaccurate when comparing to equipment distortion that can be measured by analyzers.maybe ethan w. have some figures with regards to room effects and acoustical treatmentsangelo
John.If you measure most rooms, you will see swings between 10-40 db's in frequency response. Although this isn't technically distortion, it is absolutely impacting the sound you hear in a very negative fashion.I agree that until people address the room (via proper placement, room treatments, and technology - Tact, DEQX, Rives, etc...), playing around with cables, power cords, etc... is just plain a waste of time and money.Wish I had understood this a long time ago...George
There too, the only damage done by phase shift is to the frequency response when the original and shifted versions are combined.
John, you are correct. They are massive amounts of distortion caused by any enclosed space, that are measureable in the frequency and especially the phase domain. Measuring these distortions however are quite hard as there are too many factors to test in an actual room. Testing requires an anechoic room (or a very controlled and large freefield environment) with many tests of material types, shapes and sizes to understand how the basic individual elements within a room affect the phase and distortion of the signal, so that we can then start to add them together to see how they interact with each other, and what the end result is. The problem is the large amount of testing and money that is required to do such a thing. Fortunately, you can be a part of the history making process. Just send a donation to the Eighth Nerve architectural acoustics reasearch and development department, and we'll give you the latest in room acoustic treatment designed to eliminate said distortion until we quantify all the phenomenon and adjust the products to reflect our discoveries. ...
Nathan,> I do believe that the room causes nonlinearity that would classify accurately as distortion <Nonlinearity always adds new content in the form of harmonics or other artifacts (such as aliasing), but how could a room do that?--Ethan
Anyhow, I think it is valuable to recognize that a venue "uses' the room to make the sound of the recording (or perfromance) sound a certain way. BUT....When we get into a playback room, using the room takes on a different perspective which is "destructive" to "reconstructing" the original.
That’s an interesting premise. Paraphrased, it means the sound coming from the speakers is pure and true to the source but what we hear is colored and distorted by the room. The goal then is to nullify the effects of the room.Let’s apply the same reasoning to musical instruments; the guitar, for example. The guitar sound is created by the vibrating strings which is amplified, colored and distorted by the body of the instrument. I think the first thing an audiophile/guitarist would do is stuff the guitar box with acoustical foam to cancel the nasty reflections inside. Then isolate the bridge from the soundboard with sorbothane or other constrained layer damping material. Ideally, you would eliminate the guitar body altogether and use a highly damped, non-resonant material to support the strings. Pretty silly, huh? The guitar is the guitar. Every one sounds different and that’s the way it should be. It’s pointless to try to change an instrument to sound like something it isn’t. That’s not to say that if a guitar has poor intonation or buzzing strings it shouldn’t be fixed. The same with the room: It is what it is and needn’t be “fixed” unless it is truly broken. My goal is to create the sound of the musicians performing in my room as it is. The last thing I want to make my room sound dull and dead like a recording studio....
Ulas,If you think your room will "contribute" to the original recording then go for it.
Quote from: John CaslerUlas,If you think your room will "contribute" to the original recording then go for it.Yes it does. What do you think why recording engineers put the mics in front of the musicans or above the conductor's head, not 10th row in the audience?
Hi Frank,Are you saying you feel the "reflected sound" from a 15 x 17 x 9 room will sound virtually the same as a 100 x 100 x 60 venue even when "overlaying" it?
