0 Members and 1 Guest are viewing this topic. Read 6657 times.
Yes, but it is generally more complicated than that. The actual recording is only one phase of the recording process. The mixing which is one of the most critical phases, is never done in an anechoic chamber, therefore, trying to turn a listening room into one with little to no reflection will result in you not hearing what the artist, mixer, and producer wanted you to hear.
Most good studios are not nearly as dead as most people think. They mix and determine the final sound in a room, so they are already "adding" to the original signal, by determining this in a room in the first place. Add to that the fact that the acid test is taking the CD out to someones car (I'm not kidding, every major studio engineer does this) and then possibly adjusting the mix to compensate for that environment, and you are dealing with a complete change of this precious "original signal."
So where does that leave us then, if there is no chance that we can hear the original? Well, we have to do our best to replicate the sound that was heard in the studio. By eliminating the sound of the corners, we eliminate the sound of the room. Flat wall reflection adds to the total energy of the output, but does little to define the room's sonic signature. This leaves us with an energetic environment that is free from imparting most of it's own sonic character onto the reproduction. Energy, extension, and the ambient cues that the mixer allows us to hear (or unintentionally left ) give us the best representation we can hope for in a real world scenario.
If measurements are what convince you, realize that by adding absorptive material to your room, you reduce some of the peaks in the upper portion of the spectrum and less in the lower portion. You ALSO lower the troughs as well, as you are simply reducing all acoustic energy; essentially turning down the volume on echo and distortion, which happens to be more effective at higher frequencies where echo is most conspicuous. In contrast, by treating the corners the way that we do, we eliminate a good deal of distortion in the first place, which not only reduces the peaks EVENLY across the spectrum, but also increases the troughs! Why? Because the distortion acts as a comb filter on the original signal causing peaks and troughs; by reducing this distortion, we move back towards the original signal which contains neither.
That is what our products are designed to do, and I believe it is the only way to accurately treat a room.
If the microphone(s) record a musician in a live, reflective room and you wish to hear what that microphone heard then your playback room should be far less live and reflective otherwise you're getting TWO layers of reverb instead of one. That is not to say that there is a right way or a wrong way to enjoy music IMO, but the fact remains that whatever word you use to describe it, be it distortion or reverb or whatever, the playback room's acoustics will be adding to the sound the less absorptive it is. Ob ...
Quote from: John CaslerHi Frank,Are you saying you feel the "reflected sound" from a 15 x 17 x 9 room will sound virtually the same as a 100 x 100 x 60 venue even when "overlaying" it?No, (this is one of the big problems of stereo), but without it it will be even worse ( for 2 channel playback) .
Hi Frank and I agree that there are a lot of problems with "stereo".I will say however that I have done a considerable amount of critical listening in the extreme nearfeild and under (near) anechoic conditions, and have to say that the realism and ability to hear into a recording venue (in well done live recordings) is breath taking When hearing the same recording in an untreated room the destructive effect is drastically different.Since most have not had this opportunity, I felt the concept ...
Not only that, but hearing is also sensitive to the direction of the room reverbs. If you put a stereo mic pair in a live room at normal listening distance, it will pick up the reflected sound from all directions and lump them together without the directional info.Played this back on a stereo setup even in a dead room, will not have the right balance of direct/reflected sound, because too much reflected sound ( early reflections and reverberation together ) coming from the front, and nothing from the ba ...
I know what you are talking about, I had extremely directional speakers in heavily treated room. Haven't you ever felt that you can hear every small detail of the record, but you are just not part of it? I definitely would not use the world "realism" for that....
Ulas, I don't think that is what John meant. I read that to say that we as audiophiles spend a great deal of time and money to reduce distortion throughout the electrical components of our system, but very little time spent trying to reduce distortion caused by the room and its effect on the sound. And I agree with John that the amount of room distortion is FAR greater than the distortion from our well made and very well-engineered electronics.I also agree with you Ulas that mass absorption is the wrong way to go to correct that distortion, and I have cited several reasons for my case. I think it is just as important to accurately fix room distortion as it is to realize that it is an issue in the first place. Either way, the first step is realizing that acoustic treatment is a crucial part of any system where accuracy, realism and musicality are goals...
What I hear you saying is that you feel there are some "benign" room sonics????
Let's put this in terms of degree rather than benign versus harmful. Let's say we have two things causing distortion, one at a one to one ratio, and one that is amplified by a certain amount, whether 1 or 6 db. Which would be the most important type to eliminate or at least abate? The amplified one of course. Now look around your room and see if you can identify any shapes that would qualify an as acoustic amplifier. Think about pro audio tweeters when doing this exercise. Do you see what I am getting at?...
Of course, and you can see the difference in absorption with the exact same panel mounted both ways in the Absorption graph on our web site.
