Bryston Bit 20Power Conditioner
0 Members and 1 Guest are viewing this topic. Read 1109 times.
Barilko
« on: 20 Feb 2021, 08:22 pm »
Hello
Would anyone like to chime in
maybe if I'm lucky Mr Tanner himself
when it comes to the actual understanding of the deeper X's and O's of electronics in I'm certainly no genius
so if i may ask
if i grab a Bit 20   should i plug everything into it   including my BCD3 and my 3BSST2 or does that limit the amp and CD player's abilities...
i am aware that the ears are the true test... however the purchase could happen before the ears can test
Thanks everyone....Be well
Barilko
Re: Bryston Bit 20Power Conditioner
« Reply #1 on: 20 Feb 2021, 08:28 pm »
I guess i should add is this overkill and should i hunt for a Bit 15
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 20 Feb 2021, 09:26 pm »
Hi
I would stick with the 20.  I recommend the 15 for source gear but once you get into power amplifiers I would go with the 20 for a number of reasons.
james
Barilko
« Reply #3 on: 21 Feb 2021, 05:40 pm »
Thanks for the reply and advice James...
if i may ask you or anyone who happens by
some of my source equipment has old 2 prong plugs  my Kenwood Rock Turntable for example
my older Adcom Pre Amp which is used as a Phono amp is 2 pronged as well
while my various Bryston products and  Moon phono amp are 3 pronged
i see via internet photos what the 10 rear input outlets look like
therefore the real qustion is can all of these source plugs be safely inserted or should I be changing out the 2 prong plugs
lastly and most important   the main (ill call Bit 20's output plug)
can it be plugged into my 3 prong socket in my wall  ( i would think that it is standart 15amp wall socket found in most homes)
or am i looking at an upgraded wall socket with a 20 amp line  rather than the 15 amp i would have to assume that it is now)
i really do apologize to all who may help as my electricity knowledge is obviously lacking..
« Reply #4 on: 21 Feb 2021, 06:16 pm »
Hi
Yes you are OK plugging in 2 prong products.
The BIT 20 can be ordered with an optional 20 amp to 15 amp line cord so you can plug it into a standard 15 anp wall socket.  Then if you ever change the power feed to a 20 amp service just change the cord.
best
james
Barilko
« Reply #5 on: 21 Feb 2021, 06:57 pm »
Thanks James.... the help is oh so very appreciated....
I luv my Bryston...
donpinar
« Reply #6 on: 6 Mar 2021, 03:28 am »
Glad I found a nice used BIT 20 as it makes a noticeable improvement to the overall soundstage. Just need to find a silver faceplate now.
